Preparing cruiser for soft top and bows.
Tulsa, Okla
Going to pick up cruiser next weekend. When I get it home I am going to start preparing it for the soft top.
IS there a good guide to where the loops are placed and is there any option outside of placing screws to secure them? Rare chance I am sure.
Once I get bows together, is there a certain way the rear posts mount to the tub? Bolts in doesn't it?
Is there a need to treat the canvas top before installation although this will still be several weeks at earliest.
Lastly, any words of wisdom with installing or owning a soft top?
Don't drill or even attempt to mount the tub footman loops until you get the top and bows on. I had a paki top and mounted the loops based on the straps...then went with another persons top (ocd) and the straps were not sewn in the same place. Not a huge deal, just weld the holes up and drill new ones.
Just because you mount the footman loops where you think they should be doesn't mean the top maker mounted them in the correct place.
I decided to mount with screws, but you could weld them on.
Words of advice....bring your patience, plus some more.
Figured I would seat top the best I can after bows installed and see where the straps lie. Thanks for info!
There are plates in the rear corners where the rear bow mounts into. That plate is bolted to the floor.
Wait what 40 is this soft top going on? Did you find a mustard one?
S4Cruiser,
What is the position for the main bow to be mounted to the tub? I have heard it is 15 inches from the door jamb. Yet, the previous owner mounted the bows a bit closer to the doors, making the roof taller, and not be able to button the top down (roughly an inch and a half to tall for the snaps). Anyone have the proper location?
First picture shows the Bow system, the second is a top view of the first Bow spacing from the door jamb.
Thanks,
Boaf
S4Cruiser,
Thanks,
Boaf
That appears to be a bestop or variation of one vs oem soft top. Sorry, but I am no familiar with the bows you have.
You are correct. I have the old top with snaps, and the bow is Best top. I have a 50 / 50 option as to which to pursue: New Bow or New Best top. Thanks
Best Top! It looks nice, easy to remove and no struggle to put on!!!. I'll get a picture.
Boaf!
