Prep work for the Slee 6"
Tucson, AZ
SO I'm ordering the 6" kit from Slee and wanting to do as much prep work as I can before I install the kit. some local guys from Coper state cruisers have offerd there help and guidance.:D
I have got 1.5" wheel spacers coming and I'm going to have a shop do the extended break lines befor we start. I know about the PB blaster use for a week or so befor the install. Aside from the 6" bolt on kit items I will also install at the same time Slee's rod end set, drag link, Tie rod and rear lower control arms. Should I use PB on all these bolts also?
I think I have everything covered. Anything else you can think of? anything else I'm missing as far as upgraded suspension? I will be running BFG's 35" A/T.
Not to second guess you here, but if you're going with the 6" lift, why only running 35s? 35's work extremely well on just the 4". Seems like you've got it all covered though, can't think of anything Slee has left out of his kit, but if you're buying the kit it comes with extended braided stainless steel lines.
Make sure you have some good jack stands and jacks handy.
Before you do your lift, go around and take the measurements so you know how much lift exactly you get from the springs. Center of hub to top of wheel well, at all 4 corners.
I'm going with the 6" because I like the look better. I don't think I will ever do any rock crawling in the 80 but I just want to be up that much higher.
Not going to go bigger than 35's as that seems to be the biggest tire you can run with out havening to re gear. I see a lot of people on Mud starting out on ome 2.5 only to go through all these changes to get to 4" -6". Just going to go with 6" right off. and truthfully the CNC'd contrall arms sold me on the 6"
I know it comes with the SS break lines and I will have them installed by a shop because I don't want to have to deal with them when I meet up with the fellow Copper State Cruiser guys to do the rest of the kit. Breaks aren't fun I want install day to be as fun as possible.
if I'm replacing the tie rod ends cant I just remove them with the steering dampener still attached and eliminate another PITA?
I thought I read on here somewhere that there is no height difference between the 4'' and the 6'' just more flexability
I can tell you right now, the 6' lift with 35s looks silly. 37s look perfect.
Might as well regear, you talked about people going halfway, then you went there yourself! :)
opinions opinions opinions.... everyone's got one. 35's dont look silly on a 6'' and you are not going halfway as suggested by some. im sure youve read and researched and hopefully confident on the decisions. look at schotts 80 and his rationale for going w/ the 35's. makes perfect sense. you can run them and flex more than if you lower bumpstops and go bigger. i can tell you whatever you want to hear , but ive wheeled w/ an 80 on 6'' and 35's and it did awesome; looked good too. what spring rate did you get. dan got the heavies so maybe thats why he thought his truck looked silly.
Silly? This is a fellow Copper State members rig and one of the ones I'm using as inspiration. Looks just how I want mine to with in a year or so.
I'm going with the heavy spring rates this will be an "expedition modded" 80 just with a 6" lift. (flame suit on) I have only had the 80 for about 6 months and I plan on really putting some weight on it but it will sit really high right now as It will be stock except for the 6" lift and 35's untill i can dump more $ into ARB front ,4X4labs rear and warn 12k winch along with Slee rear Drawers and fridge. I have big plans for it in the long run and if it looks a little silly until is get some weight on it I'm cool with that.
I'm even leaving my damage multiplier and KC's on after the lift until I can get my ARB. (Flame retardant flame suit on):D
You may want to spray all the bolts you will be removing with penetrating oil evey day for a while befor you start. Rear shock bolts should get a good helping.
The 35's look small on a 6" lift, because you have so much space to the top of the wheel well - they are much more uniformly set in the wheel well on a 3" lift. Visuals are a personal preference, though.
You are going to want to regear on the 35's unless you view your rig as a pig like I do (compared to other offroad oriented vehicles on 35's it certainly isn't bad) - for road use and looks I doubt you will be happy on stock gears and 4.10's, go 37's and do 5.29 gears. For that matter, that's the choice for offroad if you get to that point of getting more serious about wheeling.
It doesn't seem like money is a major issue since you are doing a Warn 12K for a rig that isn't going to see serious offroad use, so might as well nail the look with 37's and get proper gearing at the same time.
thanks Nay. Money is always a factor but my wife and I don't have any kids yet and don't plan on it for a while so have some play money right now. I do want the 12K warn as you can never have enough pulling power(ETA though on that might be a year or more). 37's and the whole regearing process just seems to extream for the kind of trail use this rig will see. I going to use it for long weekend trips on forest service roads and some 3-5 ranked "jeep" trails. I've always wanted a tall truck and with the 1.5" spacers I have already put something into widening the stance.
with the slee 6" lift and the extra stuff like the replacement lower rear control arms the drag link etc and can't forget tires I'm already up to about 5k. If I do 37 now then I HAVE to regear if I do 35's I don't. I would rather have the articulation really anyway. but really just comes down to $. I can't afford much more right now. I don't mind if it is a bit slower as l drive like a granny anyway.
:beer:
I hope you plan on loading it down heavy because Slee is NOT kidding around when they say "heavy". If you do plan on loading it down that much (700#+) in the back running stock gears on 35s...you will be spending coin on gears soon enough.
I can agree on the cosmetic comments on the 35s looking silly on 6". I thought mine did, I got 37s, I like the look better. I also can go where I couldn't with 35s on 6" springs (the tire itself is the main reason, plus the extra clearance).
I think I will go with th medium spring rate and just swap for heavy when the time comes, it wont be that much and I can probably find a buyer for the medium coils pretty easy.
I think the reason we say 35's look silly with 6" lift is because we've been stuffing the biggest possible tire under our small lifted 80's for years. The pic of the truck above looks fine, just not what we're used to 80's looking like.
X2 on regearing with 35's and esp. with a heavy load. Regearing makes on-road driving much more pleasureable just as it does off-road driving. If I wasn't regeared, I'd be reminded everyday I daily drive a truck on 35's. Regeared, you're not penialized and with Slee's lift kits which handle so well, you don't pay the price for lifting it either.
Love it!
I have been checking winches as of late--you can get the warn 16.5ti for $1,296 shipped. This version is supposed to be more waterproof. I have a small list of wants currently--need to decide what order to buy them in:)
1. winch
2. engel
3. slee 6"
1.5" wheel spacers showed up last night. think 1.5 will be enough stance change for the 6" slee?
I run 37x12.50x16 Iroks and no wheel spacers on the 6" lift. You don't need wheel spacers IMHO. 1.5 inches per side width gain isn't worth the weakness that wheel spacers introduce, especially under load. I watched a Jeep sheer his wheel spacers the other day offroad, not pretty.
If you do run them, check them OFTEN for tightness and use loc-tite or similar to make sure the spacer studs are secure.
1.5 is plenty. I am a big fan of spacers with the 6" I personally run 1" rear and 1.25" front, but that has more to do with wheel articulation. I love the stance of the spacers and extra stability, many here run spacers with the larger lifts. It will also allow more up travel in the rear by getting the tire a little farther from the inner finder well.
I have 15k on my spacers and they have never loosened, not even one nut. Wheel spacers and wheel adaptors are different by the way. The only problem i have is discount tire will not touch any car or truck with spacers or adaptors, corp rule.
"with a 6" lift we suggest that the width of the stance is increased. This can be done by using wheel spacers or different offset wheels." - Slee's website
the ones that I got where the 6061 billet from marlin crawler. I paid a little more to get the good stuff.
