I am getting some preignition/detonation when I romp on the pedal.
I usually set the timing at 12d BTDC and run mid-grade gas and that give mes great power, and great economy.
As of late, I've been having problems with the truck dieing randomly, and with preignition.
I reset the timing to factory (7dbtdc) spec, and checked the points gap, and It is STILL pinging unless I am runnign supreme grade gasoline. then it own't ping.
Still dying randomly, though.
I need to check the ignition switch.
I ma thinking that I might have carbon build up in the cylinder head.
Any thoughts on this?
Could I run a can of Seafoam through and see if that helps the pinging problem?
Thanks!
-James
Thanks!
-James
