Pre-built rocker panel sliders?
After 21 years I have some rusty rockers that need attention. Read through some really great threads here about cutting out the rocker panels and welding heavy wall sliders in place of the thin wall rocker panels. On the threads I've read through most people seem to use .125-.187 wall 2x4 or 2x6 tube with kickouts. This sounds like a good plan but before I go that route, I wanted to see if anyone out there makes a kit for this....?
If not, does anyone know a source for replacement rocker panels?
Do you have salvageable metal to weld to?
Are you doing your own welding (otherwise a waste of $$$ to go custom)
If not, welding in near factory thick metal will reduce your cost - then for sliders you can choose to either weld them to the frame or go bolt-on.
Bolt-on use great hardware if Slee, or my antique Hanna's - the U-bolts make removal to maint/improve exhaust make this my favored way.
Welding sliders into the body gains ground clearance but seems like it would put a lot of stress on body mounts if the sliders actually take hard hits. Not to mention, they are attached to sheet metal making the possibility of cracks a reality.
Also, before we go off giving you our 'conventional wisdom' of USA-centric ways of doing this, please state if you're here or if you're running a 'Icelandic Cruiser' - type 80. Meaning you run ballon tires & slide around on the Arctic ice sheet.
No location & your avatar make me think you have a Arctic Trucks -type prepped rig.
If so, while a slower clubhouse the one you really would want to consult for guys like your avatar build is here:
European Clubhouses | IH8MUD Forum
I didn't want to presume but maybe these guys are more local - ????
Help us help you by defining your use - I'll own I'm 'full idiot' on a ice sheet (and a lotta other places ;)) - but esp on a ice sheet.
Depends on your approach.
Gains of 4-6" at the rockers, and clean frame rails, versus frame mounted sliders is doable.
If you're clever about it you can maintain quite a bit of the factory metal at the door openings and along the inner face of the rockers. Add some strategic plug welds and your going to be stronger than the factory rockers.
Impact on the body is spread across a,b,c pillars and more than one body mount.
I've done this on my HZJ105, it's copped some really decent hits playing in the rocks with no sign of ill effects to the body (apart from unrelated rock rash), or body mounts.
The inside of the 80's rocker panel is not just hollow. There is a lot of texture in there, a lot of which is important to the structural integrity of the rig/body. Gunna take some notching and plug welding to form a solid base. Can be done, just gotta take your time and don't take the easy route on putting a square tube slider into the rocker position. A few have been done, but no kits available.
