Just a thought, there is an ECU Box for the hubs, it is behind the speedo, above the steering column. pull the plug out and see if that fixs the problem.
Thanks so much for that. I think that's solved my problem. I might pull the ecu and see if the capacitors are leaking. But I have 4x again. I'd love to send you my e hubs to be converted to manuals. Can I pm you?From my understanding that the ECU stops the engagement of the electric hubs above 5 mph, there is a link connection with the speedo. You may still need to push the 4WD Switch.
