Power Window Master Switch
Portugal
Hi All!
I believe that someone had already the some kind of failure or bad contact in the master window switch, the one on the drivers side that controls all windows and door locks.
Mine is now starting to miss behave and I'm looking for a solution. Since the OEM one is so damn expensive I've looking into ebay ones, aftermarket/chino, but I'm struggling to find one with illuminated switches... Does any one have/know a supplier for the solution of my problems?!
By the way the correct part number for my car, '94 HDJ80 LHD, is 84820-32150, right? Just double checking...
Cheers
Thanks!! I'll check the doctor.
Alltel05, are the switches illuminated?
There may be different versions from Switch Doctor, the master switch I installed has an illuminated Auto button but someone else reported that their's was not illuminated.
As Kernal said my auto is. I have seen a mod which illuminates a master switch... It's more of a glow kind of thing not the actual screen printing or anything.
I installed a Switchdoctor master switch about six months ago. Works great but is now acting up.
The auto down function intermittently only takes the window 1/4 way down, hit it again and it lowers all the way.:meh:
In mine all the window switches have at least a dot illuminated and also the door lock button. The only one that has no light is the children window lock.
I took mine apart, clean, buff the contacts, grease the rockers, and put it back together. Originally some windows would not go up or down. It works great now.
I did the same, worked better for ?months or a year, IDK, but then it started acting up again. It appeared to me when I had the switch apart that the contacts might have been silver plated originally, maybe when that wears off the contacts/switch doesn't work as well??
The part that is missed is to clean the plug harness with contact cleaner. I would clean the contacts all the time with minimal results and then I used contact cleaner in the wire part of the harness and the master switch works like new. Probably a forgotten part to clean. In my case with great results.
So I see... Before start buying stuff give it a proper clean. I'll look into it!
Cheers
So I've cleaned has suggested and it does feel better, but sometimes I still face the same bad contact in the switch for the passenger window.
But I didn't use the contact cleaner because I hadn't any at that time... Just sanded the contact that were completely covered with a black thin powder.
One of these days I'll give it another go but with the spray.
Thanks
Cheers
The thing to remember is that the rockers have a different metal as the contact. Because of the arching that occurs they had to use something else. So when those burn off you get intermittent connections. I have been happy with my replacement, now I just have to replace my motors.
That's pretty cool moxie. I wonder if it's the same for my 92. If that's the case it's easy to rebuild with multiple switches. And cheaper. I am happy with my Dr but I have my reservations on its longevity.
Yeh the spray is good because i also sprayed the back (green board) in case there is anything going on there too. But like i said only up on the passenger side doesn't work at the switch. So I will clean that switch just to see if that will help.
A 95 Camry switch will work too.
Anyone know if the Switch Doctor will allow me to do the Auto Up mod?
Steve very odd you just asked this question as I was about to ask the same thing. I have a SD master installed but haven't pulled it apart to see if an auto up is possbile yet.
