I'm starting the process of designing a vehicle power system and wanted to get some input from the group on a few items. I'll start with a base overview and get into specifics from there. I would like to do a one and done for the the main setup so I have a lot to consider but will scale as time goes on. The main thing I'm shooting for is safety, scalability, and as stock appearance as possible. This is an end game list as it will take me multiple phases for all the accessory items and won't be doing all the items on the list, but want to prepare if it happens.
Goals -
- 100% separation of aftermarket and native vehicle system. (A couple items seem to have to be connected to the main vehicle battery?
- Proper battery type for each application
- Identify what system activates each application (always on, ACC, or vehicle running)
- "hide" but make easily accessible all switches
Batteries - 2 AGM batteries under the hood. One for stock and one to power high amp devices, 1 lithium in the cabin for the remainder of the items.
I think the first part I want to identify is the under hood AGM battery locations. For ease of install, minimal adjustments to engine compartment items and maintain mostly stock I'm leaning toward R2M's setup with the 2 batteries in the one location. I would like to separate them for weight balance but the only solutions I have seen so far either rework the area on the opposite side of the radiator of the current battery, or putting it in the area by the air intake but that seems to require a Hewitt SAIS, and being in California I don't want to play the emissions game. Has anyone come up with any good locations for a second battery under the hood that balances the weight?
The second part is identifying which accessory goes to which battery. Here are my thoughts. Let me know if any of these should switch categories
Main Vehicle AGM Battery
Red Arc Brake Controller (would it be possible to move this to secondary AGM?)
Second AGM under hood
Winch
Air Compressor
Front Light Bar (would this be better ran off lithium house batter?)
Chase Lights (would this be better ran off lithium house batter?)
Ditch Lights (would this be better ran off lithium house batter?)
Rock Lights (would this be better ran off lithium house batter?)
Black Gate KDSS Disconnect
Power for front and rear E-locker
Power for LRA gas tank pump
Lithium House Battery
All added supplemental power for driver and passenger devices
inverter
Fridge
Rear cabin power for in camp use
Scene lighting
Water Pump
Comm's (GMRS MXT275, Ham Head Unit)
To summarize the questions for this first part. Input on the 2nd under hood battery location? Does the list look appropriate for which accessory goes to which battery. Any other accessories I'm missing? Again, most likely won't be doing all of these, but building the list for sizing everything.
Goals -
Winch
Air Compressor
inverter
Fridge
Scene lighting
Water Pump
