M
Mike G.
Guest
The next project for my 74 40 is power steering. I have an F engine with a stock air cleaner, which I would like to keep. I run 33x12.5 tires with ARB lockers. My thought is to install a mini truck steering box with modified frame mount, and saganaw pump with external cooler. My steering column has the needed rag joint for the mini truck box connection. I need to keep this project as simple as possible since I don't have a garage to work in.
I don't have a clue on how to get started. There are so many options on what to do...... Is there a "kit" available? Do the pulleys on the harmonic balancer and water pump need to be changed to double pulleys? What happens to the alternator location? What pump brackets do you use for an F engine? What parts vendor would you recommend?
Lots of questions....... Looking forward to your responses and finally getting this project underway.
