I had the same thing happen on a reman non-OEM pump, the non-serviceable plug on the back blows out and it's a big hole, it will drain as fast as you can fill it. I replaced the pump with a Toyota OEM pump, and I recommend you do the same. In the meantime, you can bandaid it with a rubber cork and backing it up with JB weld putty, then refill and bleed the system. I
did the same in an O'Reilly's on the side of the highway and made it home 2 hours just fine.
If I put the old plug back in ( cleaned) with some epoxy or sealant to hold it in will it last long enough ( until next year maybe spring time) as I'm going to do an ls swap! Will keeping this pump on cause me any further trouble with the steering box?
Thanks
Here's the procedure:
forum.ih8mud.com
And not to toot my own horn but I did this 3 times so I made a video companion
