Power STeering Whine
Thanks for the recommendation. Ill have to find one.
it is hard to find, I source it from a major oil distributor in NY, I buy it from them by the 5 gallon bucket or the 55 gallon. might want to find a local commercial oil distributor and see if they can hook you up
The nearest Graingers is about an hour away in Nashville. If i cant find anything closer that's what Ill do.
Thanks
I get the Mobil hydraulic fluid at Graingers. You need a business account which I have through work. Usually showing any business card at the counter will allow you to buy from them.
I'm a little lazy...so I just find some loose gravel and muscle the tires from chalk to chalk. no jack stands or lifting needed.
the air getting into the system is the culprit. but its quite simple to fix. set your rig's front on jack stands, fire up the engine and steer lock to lock several times and you're good to go when you see steady stream of fluid in your reservoir (no frothing).
is this done with the PS cap open?
