Power Steering & Turkey Baster
Atlanta, Ga
I just changed my power steering fluid using the turkey baster method and things are night and day from how they were before. The fluid was black before and now its filled with some synthetic mobile 1 atf that I had left over. Before the change there were some really loud whines and now very quite and smooth. Took about 45 minutes to do but it seems to have worked great. I was a little hesitant to do it this way because so many people argue against it but so far my experience with this method has been a good one.
I need to change mine as well but I can't find the Turkey Baster Method by searching...How is this process done?
never mind, I found my answer....instead of a turkey baster, you can also use a gear oil pump to suction the old, dirty oil, actually it works better than turkey baster....and cleaner, no spills on engine bay.
How the heck??? My reservoir has some sort of convoluted metal baffle just under the cap, I can suck about 1/4" of fluid out. I ended up trying to rig hoses up and starting it, spewed black PS fluid everywhere, but it's clear synthetic now. I sprayed everything down with Simple Green, and flooded it with the hose, seems alright. It whined and groaned for a while after I got it buttoned up, but it quieted. I think it was purging air, the fluid was foamy initially. Once again, glad I epoxied the floor.
I'm hauling the family up to Boyne tomorrow, then Mackinac island. Seven passengers and their bikes, and a big roof box on top. Don't need a PS problem.
Is this reservoir also a filter? It's very similar to the reservoir on my BMW, which turned out to be a filter.
There's even a calculator I saw somewhere that shows the % left of the original fluid every time you remove fluid and replace it with new. It's simple on the first change but not so simple later. Bottom line according to my recollection was that around the 5th change, you had changed the vast majority (well over 90%) of what was there. Unfortunately I can't find the calculator but I remember seeing it.
Right. The thimble-full of fluid I could extract with a turkey baster vs the several quarts of fluid in there, I'd need to do this 500 times. Do I have the only 80 with this metal plate just inside the reservoir? I changed just under a quart, not sure how much is in there. :mad:
Just buy 20 lbs. of kitty litter and yank the hose. Oil gets everywhere, you clean it up, drain, fill, burp, clean up, move on. It took longer to secure the truck on jack stands than to change the fluid. The kitty litter is still in the driveway for good measure. No leaks, no groans, no air, just good quality Power steering.
