Power Steering Screech
colorado
I've developed a slight screech when turning to the right. Fluid looks ok. Any ideas what the issue is and how to cure it?
Thanks for all the help
I’ve had two different steering screeches so far. One was a bushing in the steering column that I sprayed with white lithium grease (interior) and fixed it. The next (exterior) stopped when I got a new steering stabilizer but it was intermittent and I just noticed it wasn’t doing it anymore sometime after I replaced an older OME stabilizer.
Check your nuts.......
On the lower steering arm on the right side to make sure they are not loose.
Check your front wheel bearings at 6/12 for play.
