Power Steering Screech
Boston
Hi, I finally started my FJ40 up after diagnosing the spark issue.....thanks to everyone on IH8Mud for their help!
I'm now getting a loud screeching thats coming from the Power Steering Pulley. It is there from idle and does not increase if I move the steering wheel (which BTW the steering seems to move smoothly)
I've never started the car before, so do not know whether this is a long term issue.
I don't know whether I need to grease this somehow, or perhaps replace the box?
The car is a 1977 FJ40 and I don't think they came as standard until 79 (could be wrong here).
Can anyone identify this unit, and have any suggestions for fixing the sound other than replacing the unit?
Is there a tensioner for the belt?
I don't think so...it runs from the water pump, crank to the power steering.
Belt?
So I took off the pump and it doesn’t squeak when hand turning.
The squeal is coming from the belt.
It seems that the belt is rubbing and smoking and it’s hot to the touch.
I think that the pulleys are slightly misaligned and the belt is too tight. There is no tentioner but the bracket for the ps pump has some adjustment.
Is there a way to get the pulleys better aligned?
Perhaps a different bracket?
Toss those brackets or mod them. Any support should allow the pump to sit upright as well, so the fill cap is topmost and level. My truck came with a hack job with barely any tension adjustment allowable, but at least it is in line with the other pulleys. Can be a little frustrating, fer sure.
It also looks to me like that pulley is too narrow for the belt used on this era of Toyotas. The belt is just barely in the pulley. Look at how the belt is setting in the water pump and crank pulleys.
Don
