im replacing my power steering pump because it was gushing out the back of the pump. I have finally removed the pump but was unable to free the banjo bolt so I cut the high pressure line. 2 questions I have now are:
1.) when removing the high pressure hose, what's the best way to remove the hose clamp that is closest to the radiator? Should I take the fan and fan shroud off to better reach the small bolt?
2.) underneath the alternator I backed out the lock bolt all the way and now I can't figure out what it was screwed into, for instance is there a nut behind it that I carelessly let get away?
