M
Mike G.
Guest
Hopefully this is not a FAQ on power steering mods., but after researching the tech boards, I couldn't find an answer. I am getting ready to install a mini truck p/s box on my 74 FJ40 - getting parts together for now..... I picked up an '83 turck box complete with hoses and frame mount.
Q. Can I use the mini truck frame mount, or do I need to still get a custom mount such as the one produced by Bill Dorry?
I also picked up a p/s pump from a FJ60 (#D291)- no mount included.
Q2. Can I adapt this pump to the drivers side of my 71 F engine using a Bill D. mount, air pump mount, fj60 mount??? OR - did I make a
mistake. Should I abandon the Toyota pump and go for the proven saganaw pump? (I just have a thing about non-Toyota parts under the hood
- I'll get over it if I have to though)
Q3. Does any one have any pics of where I will be remounting the alternator on the passenger side? There are a couple of tapped holes on top/front of the engine head - do I use these for mounting the FJ60 alt. bracket?
Still need to locate a double groove harmonic pulley, double water pump pulley, Fj60 alt. bracket. Any good sources for these parts??
Thanks for your info and suggestions.
- I'll get over it if I have to though)Q3. Does any one have any pics of where I will be remounting the alternator on the passenger side? There are a couple of tapped holes on top/front of the engine head - do I use these for mounting the FJ60 alt. bracket?
