power steering pump whining need advice
Redondo Beach
This may not be hardcore but I need some advice
I am trying to load the rig up this weekend and go on a 2 week crawl fest and I only have this weekend to solve this issue
I am trying find a solution
Recently changed the power steering pump and added a remote resvior for my hydro assist
I originally modified the ham o can to accept a pipe to AN fitting but later changed to hydro boost style can
Plenty of pressure and return
using amsoil
Amsoil fluids CURE full hydro steering issues for team Red Bull!!! - Pirate4x4.Com Bulletin Board
The pump whins when turning much like when at full turn and the belt is slipping
I thought it was air cavitation issue and or air bubles but I have bleed the system over time and the whinning wont go away
Any suggestions would be helpfull
Thanks
which it's your pump .. ? are you using a stock ( for your pump ) pulley .. ?
Thought you have oil coolers .. did you have measure the oil temp ( IR thermometer ) ..?
I have some whine when the PS fluid its over 160°F ..
Rebuilt pump from a reputable guy in town.
Pully is OEM
Never ran the system up to temp so I have no idea about tempature
Thanks for the suggestions. I am going to work on the rig tomorrow (sunday) and try to get it all worked out.
I will get your prefabbbed 4 link done this weekend as well..... LOL
Maybe try the 40 section?
I hear ya......maybe everyone is out Christmas shopping, but I got my money on the pump :D Thats why I posted the pics because I just did all that and I had a BRAND NEW pump right out of the box make noise. How's the pressure when turning? Does it turn well or is it restricted? With the assist I don't know if you can tell......Pump pressure maybe..:confused:
Thanks for the input
Got it all worked out today
Two problems
had a small leak in the can and it was sucking air
and I am guessing the pump was bad
Installed a new can and a new pump and everything works great so far
Thanks
