Power Steering Pump Super Leak
Kennett Square, PA
Website
cruisin4parts.com
My Power Steering Pump always leaked a little bit. I would replace the stuff every 2 months. Now, its like everyday. So, The leak, wherever it is, is big now. I'm almost certain its the pump because all of the oil is leaking straight down from the pump. Is there anyway I can seal the leak with one of those pour in leak sealants?
if not, how much is a new pump?
Has this pump ever been worked on before??
Reason being, often the mechanics will forget or neglect to replace
the banjo crush washer that hooks up the high pressure hose to the pump. This washer MUST be replaced with a new one if the hose is
ever taken off; no amount of tightening will make it seal up;
I speak from experience.
If you haven't done it already, clean off the entire pump
and watch it very closely; ie: take it to a car wash; switch to engine clean, and spray from below up toward the pump, and also from
above down. Then watch it to see where it is leaking from.
Could be the washer, could be a hose, could be the form-in-place seals, etc.
Good luck.
g
In my experiences with different types of stop leaks, nothing works really great, it might slow it down for a bit, but you're going to need to have something replaced/tightened, etc.
Mine leaked when I got it............it was a 5 cent O-ring.
Don't jump the gun untill you figure out were the leak is.
Just my 02 or 05 worth...
g
Great advice... I think I'll look into that for my own leak :(
O-ring part # 90301-73004
Could be those O-ring?
The one that is on the end of the reservoir hose (the fitting that plugs into the pump) with the 14mm? keeper bolt.
single small o-ring, i'm guessing from memory about 10mm.
One symptom that I had was the pump was making noise (sucking air/cavitating) when the fluid would get abit low.
Dripped about a teaspoon over night.
Crap.......... sorry guys ........wrong pump
thanks Curtis.
PS leaks are common on older, crustier trucks. I rebuilt my PS pump after it had started to leak from the rear seal. That lasted a few years and was easy to do, but it started to leak again. I purchased a new Toyo pump and turning the 36" tires is much easier now.
The high pressure lines tend to weep over time as well and they're a PITA to replace. There are no banjo fittings as previously mentioned. The high pressure lines are compression fittings and I've never seen them leak before.
Another place the pump can leak is the junction between the reservoir and the pump. Again, a rebuild kit will take care of that.
In any case you need to figure out on your own where the leak is coming from. If you need to fill it every day or 2 it'll take you all of 60 seconds to find it. However you do have to look for it.
Maybe, but that's not from a '92.
Come to think of it, a few of the replies here probably don't apply to the belt driven PS pump on a 91-92.
Curtis
Correct; I missed that also from the original question; it is down
my his signature line, not in the body of the question.
The cleaning point is still valid; can't find a leak if you can't see the leak. Do they use crush washers on the high pressure line?
g
I'll power wash around it and scrape off the "crust" when I get a chance. I'm glad most people didn't say, "Yeah, that's one thing you gotta replace". I'll look in my Haynes Repair Book too. Thanks.
