power steering pump pressure valve?
oregon
Howdy, ive got a 93 that im having some issues with. The return hose blew out about a month ago, so I replaced it. A few days later, the hose blew off without damaging it, then again a few days later. I double hose clamped it on each end and had no sign of issues for a couple weeks. On my way back from a hunting trip, It decided to blow the hose again, splitting it (up in bend, or a few days ago right after a nice snow storm). The day after thanksgiving, im running around trying to find a solution, which I could only find another replacement hose and nervously drive another 500 miles home with extra hose and fluid. I understand that these pumps may have a pressure valve that can get bumped, or clogged and create more pressure on the low side. Anyone have any experience adjusting this or know where it is on the pump?
Thanks Hornd. I read the post and failed to find anything pointing out a pressure switch. Would you mind pointing out which picture or page its on?
What hose, pic? The return is exactly that, return to the reservoir there is nothing in it to build pressure, unless there is a kink or something.
Post #8 Top Picture. It looks like a nut.
I think it is a one way valve so that pump can pressurize oil on High Pressure side and oil not flow backwards into feed line.
The low pressure line that you are blowing off should be very low pressure.
Did you try to double hose clamp it till you can figure it out?
I did double hose clamp it originally. my first "fix" I used 250 psi fuel line and double hose clamped it, then it split open. The hose I have on now is 400 psi line, but it will not go on far enough to double hose clamp it. I drove it for about 30 minutes, then tried again to see if it would flex more, but it would not. Do you have any idea on how far or even with direction to turn the pressure switch? There's nothing on it in my land cruiser tear down manual and all i'm finding online is simply that it exists.
It turns out just like a bolt. You going to try to clean it then reinsert?
Something is not right.
There should never be that much pressure on incoming line?
I was thinking of bleeding, then blasting out the lines with my air compressor. maybe some buildup is affecting the pressure, but it could be the pump itself acting up. One way or the other, I need to figure out why its pressurizing the line.
I was thinking of blowing out the lines with my air compressor first to see if there's any build up or crudd and checking the switch. Not sure what else could be causing the line to pressurize like that.
Fuel line is not rated for oil, it should have TOC (transmission oil cooler) line. Over time, oil will soften fuel line, causing it to fail. This shouldn't happen in days, maybe?
There is no pressure switch. In the high pressure port, on the pump, there is a flow control valve, this has nothing to do with return pressure. What line are you having problems with?
