Power steering pump leak
Pasadena, CA
Website
forum.ih8mud.com
Local stealership quote $329.00 for new pump :frown: Dan do you new pump in stock? Now is it rebuild or brand new pump?
Also what else need to be replace beside pump and hose? Any other recommended?
Thanks :beer:
Are you sure you don't need someone to take all your old worn-out parts off your hands?
:D
-B-
I just replaced mine, smart shopper price was around $240. I'd replace the low pressure line while you're in there, a lot better than replacing it on the trail and cooking your hand on the alternator.
... replacing it on the trail...
I don't think trail repair is anything LX_TREME will ever have to worry about!:lol:
If it's just leaking, get the seal kit? It's an easy build and as long as their not run dry, they last just about forever.
Crazy stealership...
I went to local stealership to get quote and ... nightmare :mad:
1)Brand new PSteering pump 44320- 60182 - $ 360.56 and with my discount $ 306.48 :eek:
2)New return hose 44348- 60170 -$27.35
3)New pressure hose 44411-60430- $222.35
4)Last one I dont get it, What's this 44420-60221 cooler assy - $320.69 :eek:
And I asked the guy that belongs to the P/Steering :confused:
I guess Im going to wait 'til CDan back from vacation..
Mine was leaking pretty bad from the o-ring at the bottom of the resivior hose (were it is attached to the pump).
Dripped when parked and sucked air (pump cavitated) when fliud was just abit low.
One 50 cent O-ring and good as new:).
LX_TREME- I wouldn't think your power steering cooler would be rusted or otherwise leaking, so why did they quote that in the price? Have you verified if your power steering cooler is leaking or otherwise in need of replacement? That pressure hose + cooler kills you on price. Time for CDan (when he returns)!
I'm with bro on this. Toyo PS pumps are the best in the biz. They are rebuildable. I have rebuilt several. It is not that hard!
A pump is upwards of $200. but a rebuild kit is less than $40 from the dealer or less than $20 aftermarket.. The hard parts of the pump are sturdy and hold up well. I have rebuilt Toyo PS pumps at well over 300,000 miles with good results.
It is not rocket science. The pump is simply a mechanical device that converts rotation into hydralic pressure. It contains several seals and a series of fiberglass vanes that transfer the pressure to the system. The seals can leak, and the vanes may crack or break. You can fix these problems.
The rebuilders make a living on your personal uncertainty. They buy a $20 rebuild kit and charge you $200 extra for peace of mind and a warranty. That makes you feel good. You have a warranty! You are covered.
This does not mean that the unit will work. It only means that you will feel good by having a warranty. Do you feel cozy yet?
If you want that, then go for it!
I might suggest that you buy the $20 kit and make your own rebuild. Trust yourself! Make your own warranty. You could learn a lot about your truck and save money. Try it!
Replace the high pressure line as well. If the rubbers on the pump is going, the high pressure line is not far behind it. You can buy TOYOTA oe or take to a hose shop to have it fixed, however by the time you do that, you are into the same cost as a OE line. Only time we fix them is when we do turbo installs and we need to route the line different.
The low pressure line is only sold in a full hose kit from Toyota, that's why it's so expensive. You can get 2' of 3/8" ID LOL hose from a zillion places for $5. The high pressure line is available from Gates for about $60.
Must be the hard line assembly sits close to the radiator, connected to the low pressure hoses.
I love the design of this hardline being the "cooler"! :rolleyes: Has anyone just bypassed this cooler hardline? Does the PS fluid need a significant amount of cooling? If so, has anyone ever mounted a aftermarket oilcooler and plumbed the PS fluid through there? Hmmm. :idea:
I have to replace mine, because it has rusted through and now is leaking. I was just looking at it up on the lift at the dealership and now understand that it's not a big deal to replace (effort-wise).
My first advice is to remove the skidplate for better access and visual. After draining the PS fluid, detach the 2 hoses and unscrew the mount points. Then just rotate up as you're pulling it towards you. :banana::banana:
Dealership cost (retail) here in VA @ Koons Toyota is ~ $290. If you know a mechanic to get "his" price, you can get it as low as $210.00.
Of course, the fun of it all is dealing with the PS fluid. Anyone care to elaborate helpful tricks dealing with that to reduce mess? Can those hoses handle being pinched off without damaging them?
Also, if I'm replacing the "cooler" hardline assembly, do I need to be concerned with replacing any adjacent hose lines while drained and accessible?
Cheers,
Sean
Cory, which part number corresponds to what you're referring to as the "low pressure line"?
And, what comes included in the "full hose kit"?
Thanks,
Sean
A couple of months ago, I replaced the pump and hoses. My pump was leaking, plus the PS fluid was overheating on the trail. Here's what we did to La Cabra:
Power Steering Cooler Install
Regards
Alvaro
Thanks,
Sean
There isn't an individual part number for the LP line, it's only sold in the hose kit. Not sure what else comes with the hose kit, Dan would be able to tell you. The hose from Toyota has a formed bend in it. There was a hose from a Previa that had a similar bend, but I think they're all gone too (mysteriously hoarded in Albuquerque before they were sold out there too).
Thanks to you all especially to Slee ;) and Alvaro that’s very nice article.
And Yes I also want to know the Low pressure hose kit, could be this one? Part # 44348- 60170?
So I have to remove the battery and the battery tray uh? SOB…Im tired :frown: Last time I just removed it to install new alternator, new radiator..etc.. now I have to remove the battery tray again??
Alvaro, I was reading through your article on the power steering and Im writing few tools I need…
High pressure on the pump side – need 6 side 22m socket.
Just two questions here, the 17mm flare nut wrench? What’s the flare nut wrench?
And one more thing do you have pic of the factory steering cooling system? And the part # of the factory cooling system? 44420- 60221 list as cooler assy?
The power steering's "cooling assembly" (part # 44420) is actually the hardline you see when you look behind your bumper that pokes out between the frame and sits just in front and below the AC Condensor.
Hey guys - just dug this thread up - because my power steering pump cooler lines appear to be leaking. I thought they looked wet a few weeks back - and then I started to hear the moan from the pwr steering pump. Dont know if it's as simple as an o-ring - or the whole line (they look REALLY rusty).
But the question asked above was never answered. How much cooling does the pwr steering fluid need? Could you bypass the cooling lines in the winter and repair when the warm weather returned?
