Power steering problems??
Pequot Lakes MN
I have a 1997 lx. Great truck. It almost seems like the power steering is not working but i know it has fluid and seems to be working. (Not big tires, maybe 265s) It is just more difficult to turn the wheel than i would expect. I have never driven a different 80, but own a 40 with mini truck power steering. I have had a few tundras, 4runners and a 100, this is by far the most difficult to move the wheel. My gf does not even like driving it.
Is this just how 80s are or do i have something going on?
apeterson, does the PS pump moan and groan when the wheel is turned? If it does and the reservoir is full it needs to be bled. Is the pump leaking and in need of a rebuild? Has the steering box ever been rebuilt? I'm thinking it's gotta be one of the two (pump or steering box).
As far as i know its original. I have a few oil leaks i just addressed so still cleaning up oil oils. Yes the lines are wet but i think its oils motor oil being flung on them from as ps reservoirs never needs fillibg up
No noticeable noise from pump or box
The pump has a pressure control valve that might be stuck. The valve is an oddly shaped machined part that sits on top of a spring and a plug holds the part in the pump housing. Something is restricting the fluid flow. I'd start with the pump and rebuild it. A Toyota rebuild kit contains everything needed and is around $60. The FSM gives you step by step instructions on how to rebuild it.
Ok. You got a part number for tge rebuild kit by chance or is it in fsm. Sorry i am not at home
Can you unstick it without removing the pump or is it part of the pump?
It can be accessed by removing the high pressure line on top of the pump. The plug I mentioned in my earlier post is actually the Pressure Port Union, an o-ring is under it, then the flow control valve, then the spring.
apeterson, did you fix your PS issue, if so, what fixed it?
Unfortunately i have not yet.. the girl has me tied up on a kitchen project so i am still strong arming it.
Was seriously contemplating just buying a new pump and putting it in
I would put the front axle on jack stands and make certain there is no mechanical issue first. With no load on the tires and the engine off, it should be effortless to move the steering wheel from lock to lock.
Then remove the jack stands (engine still off) and have someone rock the steering back and forth as you visually look and feel the 4 individual steering rod ends.
Ok.. thats makes sense and is free :)
X2 on what @jonheld said in post #14
Do you have to take this off to get to pump?
If the crank pulley bolt is loose, the oil pressure will be affected also (low). The gear on the crank drives the oil pump and PS pump.
I must admit, I don't understand how a loose crank pulley bolt will cause oil and PS pressure loss. Both the pump gear and crank pulley are keyed (secured) to the crankshaft. Even if the bolt was loose they both would be secured to the crankshaft (made to turn) by the key. If the bolt became loose enough for the pulley to back off the shaft, then yes that would be a major problem.
