- Thread starter
- #41
Do a good write-up when you do!Flush on e until the fluid runs clear then some time later flush again. His will allow the varnish to be dissolved by new fluid then replaced again. That is what I am going to do.
When I arrive home tomorrow I will link to the write up I followed.Do a good write-up when you do!
Thanks @LandCruiserPhil
What are you running for a cooler? I've been looking at the finned, cylinder type, but a small grill type/trans cooler would seem to cool it better.
Thanks, great to know!None, PS system is 100% OEM except for the use of Mobile 1 DTE24
Anything special about switching over to Mobil 1 DTE 24, maybe the RavenTai flush method?None, PS system is 100% OEM except for the use of Mobile 1 DTE24
forum.ih8mud.com
I have mix the 2 over the years without issue.Anything special about switching over to Mobil 1 DTE 24, maybe the RavenTai flush method?
I'm currently running Valvoline maxlife ATF transmission and power steering not finding much on compatibility for the power steering hydraulic system.
How to change Power Steering Fluid
By request I have combined & condensed several posts by myself and others into this one. Why change it? Power steering fluid is usually an ignored fluid, but over time and especially if overheated it can break down, oxidize, change viscosity, consume its additives, be contaminated with solids...forum.ih8mud.com
