power steering leak question
I have a question about a power steering leak on my 93 FJZ80. I wiped everything down around the pump and was able to spot a leak coming out of the hose going into the pump closer to the front of the vehicle. It was freezing cold and I didn't really feel like messing with the power steering hoses so I took the truck over to a mechanic that i trust and showed him the leak. He said he would order two new gaskets for the hoses on the top of pump. It has been a couple days and the washers or gaskets still aren't in. Where can I get these washers and are they pretty simple to install? Do I have to order these through Toyota? I am tired of leaking power steering fluid and adding fluid and just want to fix it myself I guess.
Gaskets.? Not sure your mechanic understands this vehicles
Is it the big hose from the reservoir coming down in this picture? You would replace the hose with one from Toyota.
attachment.php
Take a look at this thread and maybe that will help you
https://forum.ih8mud.com/80-series-tech/201920-power-steering-pump-hose-replacement-faq.html
Course your 93 setup could be different than my 97
Most likely the O-ring on the end of the res hose where it attaches to the pump. 12mm bolt holds the lock-tab. Hose fitting has an O-ring, easy :banana:job to replace but you need the right O-ring as it is a fairly precise fit.
By the time you take that off, you might as well replace the High pressure hos. You can get a NAPA one for about $50
could the mechanic be referring to the copper washers on the banjo bolt? its a common washer that you could purchase anywhere. but i doubt that is the problem. must be the crimp fitting of the pressure hose. you could replace the hose assembly as romer suggested. i had mine pressed by a machine shop.
