power steering kit prices
I am looking to add power steering to my 72 fj40. I've looked through the 2 junkyards near me and no luck with 4wd mini trucks. So I am now looking at kits. Is 1000 dollars a decent price for a everything included kit? I was looking at iron pig and I see some of the other big sites are right around there. I just dont want to spend a grand on this and than find out I could have saved a few hundred and put that towards something else the blue beast needs. Thanks
holy crap
obviously, you are looking at just the minitruck box swap? Post up in the Wanted corner here for a box, generally $40-70 including freight...add in a bracket for $100ish and hoses for $50 and a pump for $50 and some engine bracket fab work and yer said/done for $400 or less.
All the other PS options can be done for similar prices, IMO...with some effort, all are $500-less projects.
There are 3 or 4 1979-1985 Toyota mini-truck power steering boxes on eBay right now. Some include the pump and some are just the gear box. Even with the shipping cost you're looking at quite a bit less than a $1000 kit.
Patrick
$1000 is a decent price if you don't want to do any foot work. You will get a box, dropped on your front door, with everything you need.
That said, you can do it MUCH cheaper if you want to do some runnign around. I did a Saginaw PS conversionfor less than $600.
I have a list of everything you need for a SAginaw PS conversion, including part numbers from the various stores for all of the parts to do Saginaw PS on an FJ40. You would need to have a scab plate made for the frame, then have a competant welder install it. I was considering putting together kits, but after investing in the tools necessary to make tie rods, paying myself for the running around, etc. it would push the cost to, you guessed it, over $1000.
I've got a mini truck box mount (new for $75 plus shipping if you want it.
Later,
Ignition key on the dash or in the column?
What size tires do you plan on running?
What kind of wheeling will you be doing?
Mini truck conversion on a pre-9/72 is a bit more of a task...still doable, but a lot more screwing around...
Good luck!
-Steve
I have the Bracket from lance and the complete mini-truck box, pump, lines, and cooler. I also have a bracket to bolt the p/s pump to the engine. I also have extra drag links and relay rods.
pm if interested. I live in Richmond, Va
the ignition key is on the dash.
I have 32's now but will be jumping up to 33's or possibly 35's
mild wheelin occasional trips up to paragon in pa
Then you may want to look at saginaw, scout or 60 series over the mini box set up. They will give you less moving parts in the system compared to the mini box set up, and, will be easier to connect your existing column to.
These conversions have been discussed out here to great lenght, a quick search will give you HOURS of reading material.
Good luck!
-Steve
