Power steering help
I am trying to replace the high pressure line on my power steering pump. When looking at the pump it was discovered that the banjo bolt is stripped in the pump and long story short I need a new one. Does anyone know the parts number or where I can pick up the bolt? Thanks in advance
My power steering pump is going out and I need to replace it. Should the high pressure line always be replaced at the same time? Otherwise, how do I know if it should be replaced (other than the obvious)?
When it leaks, I'd replace if you never have can get one from Napa like 60 bucks, old line is prone to bursting in the bend mine did, it was 14 years old
