Power steering gremlin
Hi ya'll, this is my first post so go easy! I searched as much as I could about the power steering topic for my problem but didn't get a clean cut answer. My power steering works fine for the first fifteen minutes of driving, but after that time it starts to go, and soon it's all the way gone. Can't turn. I can, but there's absolutely no assist. I'm too much of a wuss to drive like that all the time. I need my power steering! Fluid is full, no leaks. Just curious of your guys' past experiences or knowledge of it. Does the p/s pump go out gradually? Or all at once? Can it be rebuilt? :bang:
there is a write-up in the FAQ on the rebuild of the power steering pump and gear box.
The FAQ is the thread below the announcements titled FAQ for 80/LX450 seris. Scroll down to the maintenance section, I think its in there.
Is your oil pressure OK. Reason I ask is that if your crank bolt is losse then both the oil pump and power steering will have issues so lower oil pressure. It normally goes a little lower after it warms up, I mean almost no oil pressure.
This write up relates to seals 'n stuff. My pump is not leaking. It's not working. If that makes sense... after about fifteen minutes of course :bang:
What I was originally trying to get at was whether or not a person could rebuild the mechanism of the pump, without paying the astronomical price for a new pump. Like the little vanes and such. I wanted to get into the nitty gritty of a pump failure. Cause in my air tools I can take an air drill that's seized up apart for example and rebuild it, make a new vain and what not. I just didn't want to disassemble my cruiser to find out. I was hoping someone else did it already!!! Johnny 5 alive!! No disassemble!!
The pumps can be easily rebuilt, but they are simple, robust units. The most common failure is seals, leakage, for them to fail to make pressure without making a bunch of noise is very rare. Working one minute and not the next is usually the drive. It's driven off of the crank, the crank drive gear isn't keyed, so if the crank bolt isn't tight enough the gear can slip and you will have reduced and/or no power assist.
