Power steering blowup?
Austin, TX
I replaced my front rotors and pads today along with new bearings. I had the front on jacks and to access the brakes easier I turned the key to On a few times and turned the wheel. Didn't think much of it.
I went to start the cruiser after I was done and immediately heard a wirring sound. I drove it for 10 minutes and went through a bed-in for the front pads and rotors. It was making a lot of noise and when I turned the wheel tons of noise and significantly harder to turn.
I get back to see a puddle where I started the car with drops leading out and then a puddle still forming at the front of the engine.
Kicker is, it seems like its engine oil. Ill admit I never changed the PS fluid since i bought it a year ago so could PS fluid turn brown? It was somewhat milky as well.
Im afraid to even start it, should I go get some PS fluid fill the reservoir and see if that dumps out? Did I royally mess up turning the wheel with the key on but the engine not running?
Can't be possible can it?
yeah youre right, it can be. But my steering is rough now. I started it and there is noticable fluid (oil it appears) coming from one if the hard lines in front of radiator.
thinking i need this: 44420-60221
Oil cooler lines?
Anyone know what Im talking about because I sure dont.
Ive gone through my manual twice and havent found this hard line. It appears its a low pressure power steering return line?
Feeling pretty dumb feel free to confirm, thanks.
Well first, check the level in the PS reservoir. Is it full? Because it sounds like you exploded all your fluid, so it will probably be empty. Sounds like its coming out fast, too. Buy some automatic transmission fluid, which is what the FZJ-80 uses for power steering fluid. Put some cardboard/tarp/pan under your truck, and fill your power steering reservoir. This is just an experiment to see where it's leaking from, so expect more fluid to come out. Find out where that is, and that's your problem. It could be possible that it won't come out until you start the truck.
Yup thanks for the reply. Its definitely the PS paperclip. Im just going to do a cheapo cooler replacement instead of forking over 200 for a new paperclip.
I dumped some ATF into the empty reservoir and its clear that this is the issue.
Just coincidental though? Can't see where turning the wheel with key on / engine off would be the cause.
must have been! the lines are rusted to hell so its not surprisingly but they could have gone anytime over the last year besides today.
Mine has been bypassed by a regular line for years. It doesn't get hot enough for it to matter here and it was also a bonus type bit of extra mile engineering that the need for is debatable 25 years out. Unless you are heading south for extended periods of time, I would just skip it and rip it off and throw it in the bin. I change my PS fluid regularly and I have never had any issues running with the hose I have now, which is close enough to the fan that it's probably getting some sort of breeze. I think the bigger issue is leaks. I am lucky not to have any big ones, but that seems to be an issue for some.
You can get an aftermarket cooler at Summit as many of the guys do.
Do a little searching.
You likely do not want to give up the cooling in the summer which will save the oil from premature death.
I am saying it doesn't matter. How many other cars have power steering coolers mounted under the bumper from that era?
I mean, sure, running one of those aftermarket coolers does look neat and it probably does something useful, but I don't see how a length of hose is all that crappier at cooling the fluid, especially if you are crawling and there is no wind speed anyway. I would rather have a sealed system than one that was leaking.
It was just anecdotal advice :) My way is the $12 option, your's is the $112 option. I can say for sure that either one works fine in places that rarely get over 100 degrees F.
In the desert, I would have fans everywhere. And sails. Light sails...;)
These units are overbuilt, and that's why they have cooling.
I feel if Toyota needed it, and someone did the heat load calculations, and thought this out like these rigs could be sent into orbit. I'm mimicking their obsession.
All in all your prolly right that it will be just fine without, but oil might not last another 20+ yrs like it already likely did.
thanks guys, so I went with the suggested bypass until I get the delivery of a cheap 2 pass cooler.
Im happy this thing blew up in my driveway instead of 5 hrs from home. I chopped the paperclip out and ran about 3 feet of hose to act as the cooler until I get around to installing the cooler.
It will be sub 50 degrees here for the next week and likely until next March so I think itll be ok.
Most/all cars and trucks have some sort of power steering cooler--whether it be an extra length of hard line (which is all the 'paperclip' is), or a finned unit. Next time you're browsing a junkyard, take a look. There are some cool configurations if someone wanted to do something different. I grabbed a smallish rectangular one from a Ford Expedition to put on my 100.
Nice, thats essentially what I bought on amazon for 15 dollars, hayden 12 inch cooler.
Im thinking Im going to mount it on the cross member where the old paperclip was though, anyone have any issues with rock strikes? I have an ARB winch bumper.
I Have Boiled the fluid in my power steering rock crawling with the stock cooler in place. replaced it with a after market in stock location with no issue.
