Power Steering Bearing Press
North Front Range, CO
I need to put a new bearing on the power steering pump.
It says to press on the new bearing. I don't have a press.
What do I use in place of a press or do I need to go to Harbor Freight and get a press?
And would that be a arbor press? Anyone have Harbor Freight discount/coupon???
It depends on the individual bearing. Usually, it is harder to get the old one off than the new one on. If you have the old one off, you have several options to try, including freezing the shaft to shrink it and heating the bearing to expand it so that is will slide on. You can also try pressing it on with a vise or C clamp or you can go old school and "walk" it on with a drift punch and a BF hammer alternating sides of the bearing race that you hammer on.
I didn't get a bearing with my kit but I called around and the 6203Z bearing is quite common. I have a choice of KOYO, SKF (Chicago Rawhide) and some china crap.
I assume the KOYO of Japan would be the way to go. Don't know much about SKF.
Koyo $8 and SKF $3.
The bearing says 6203ZZC3 on the box> The guy says its the same bearing but its rated for use in an electrical use. Said its fine in any other use as its the same size bearing just rated higher for other uses.
