Power Seats Question
Hi...
My power seats stopped moving backward and forward. They still recline. Both white caps are missing from under the seat(doh!!!) Tried replacing one with a friends white cap...didn't work.
So...is there any way to manually move power seats...I'm sure I have to remove the seat from the Cruiser...but then what do I do?
Any help would be greatly appreciated!
Henry
do you here the motor running when you go to move the seat?
You need to replace the gear assemblies in each seat (the gizmos that the caps fell out of). They will run ~80 bucks each.
I've replaced DS and PS. Yes, you can move it manually. Reach under and spin the shaft where you want it.
-Eddie
cool...sounds easy...i'll try and move them manually for now...i'll let you know how it goes...thanks for your help! if that doesn't work I'll contact cruiser dan for those gear assemblies ..
thanks guys!
-Eddie
You need to disconect the power or you can do as simple as moving the shaft ?
