Power flat spot
Auckland, New Zealand
Hi Guys, I've noticed a reasonably prominent flat spot in the power output with my 80. Cruising, 40kmph through to 50kmph the road gradient increases slightly and the revs reach 1700/1750rpm ish, and it feels like I've eased off the throttle. it just flattens off and I have to push the accelerator another 20% or so. Then it overcomes it, revs get closer to 2,000rpm and she's off as you'd expect.
It feels like it's just gone into some soft sand and the power has been sapped. If I do nothing, leave the accelerator pressed as it was, it continues with really minimal power and takes an age to build the speed. It's not a temporary condition, it seems to be a state it gets into that is only overcome by adding more accelerator. Before the 1700rpm it was accelerating OK, so it's a really noticeable zone of flat spot, when you're just cruising and expect the low rpm torque of the motor to do it's job.
Would this be fuel filter related? Or is it perhaps the point at which the turbo starts to boost, and it can't spool up freely and quickly enough?
It's a 4.2 Diesel Turbo, 24 valve. Stock condition, 205,000kms. Otherwise very tidy, doesn't even blow any smoke, starts in a nano second if you turn the crank 1/100's of a revolution. Runs really reliably, efficiently, no other issues.
Any suggestions for where I may start to investigate appreciated.
Cheers,
Pete
I have something similar on a '94 gas powered engine. 1500 RPM (almost exactly) and I have a flat spot. Almost feels like a misfire but it is so subtle. Once i get through 1500rpm i am good.
You realize the power come on much better when Yugoslavia gasser gets over 4000 rpm?
Cheers,
Pete
You should ask this question in the Diesel section. You'll get a lot more useful response. Diesel Tech / 24 volts
Could just be your boost compensator needs some adjustment on the injection pump.
cheers mate, I'll do that. Thanks for your suggestion also. If a boost compensator adjusts the fuel/air when the boost starts to come on then I agree this could be likely. I had certainly been wondering if it was associated with the commencement of the turbo pressure coming on line. It seems that that's the new thing happening (or supposed to be happening) at that time for those RPM. I'll see what the guys there say. I forget that the diesel engines aren't that common in the USA.
