Power cut while driving
Bozeman, MT
Yesterday after driving ~200mi, at the end of my drive, the ABS light came on on the freeway and power was momentarily cut (<1sec). This happened ~5-6 times over the course of 10mi in a hilly stretch.
After getting off the freeway, it started happening frequently (~10times in 10 mi) and the power was cut for significantly longer, ~3-10sec, lights out, etc. My PS low-beam appeared to have blown out. The 'strongest' power outage was seemingly started when I hit the left hand turn signal.
The wiring loom near the EGR appears undamaged.
The previous week I've been having intermittent starting issues, one 'click' but the engine won't turn, seems to be immediately resolved after playing with the positive cable.
Additionally, I've had P0401 coming on for a few months, yesterday's incident will be the motivating factor to start troubleshooting it.
Any advice on where to start? Any help is greatly appreciated.
you mentioned jiggling the battery cable. have you checked the condition of the terminals? Also, get out a VOM and check that the other basics like your fusible link, EFI relays, fuses.
The terminals appear fine, the battery was replaced in the last 2 years, when I get home I will be replacing the fusible link and inspecting the EFI relays + fuses.
Definitely sounds like corroded terminals or wiring. Can also be on the ground side. The terminals can look ok on the outside, but be corroded underneath. Get a battery brush and some terminal cleaner (and plastic gloves) and clean it up, don't be afraid to pour water over the battery to rinse it before re-install. I usually will pull the negative, brush both the terminal and the post with a battery brush using terminal cleaner and then pour water from a bottle over the post and the terminal. Repeat with positive, and then re-install positive and negative, tighten down and then spray with terminal protector. Check the fusible links for corrosion as well, but with the <click> starts, i would bet that just getting the terminals cleaned up properly will take care of the power issue. If you see a lot of green up in the wires leading to the terminal, you may need to start replacing cables that are corroded.
I doubt P0401 code is related to the click start issue or power loss.
Did the OP find a solution? It's always nice to close up a thread properly if possible!
Thanks.
Battery is my guess. I had a very similar situation in my Tundra and it was the battery.
