trd55 said:Thanks for the heads up. I found one today with a head gasket issue. Knocked $1250 off the price. How does 2750 for a '91 w/ 141,xxx miles sound. We ran it and it ran fine until it started getting hot. Revved good, but had trouble idleing(mu guess cause of head gasket). All else ws good. New alt, water pump(wanna be mechanic trying to solve HG issue). I will look at the faq and go from there,but your input is greatly appreciated. I am new to this 80 thing. This willbe a daily driver. The 60 is for wheeling. ; ). ANy idea on a HG job from the dealer, or otherwise? I do not hink there might be too much messed up with it.
Thanks,
Darius
sc40 said:where do you look to find deals like that
SHREG said:Just picked up a 91 for $500 bucks with 175xxx on it. runs, drives and looks great, interior is solid, need a bit of TLC..... I would keep looking.....the deals are out there.... Not sure I would take on a HG case for that much. Hit the guy with the $600 hammer and do him a favor.... Not worth $1200 with that much work.
Figure out what you want to spend and what year you are looking for. Be patient, one will come along.....
Jason Andrews said:Holy s*** are you serious??? That is a ***in steal! Good work!
Thanks,
Darius
photogod said:Head gasket on a 91 isn't that common, I don't think, beause of the cast head as well as a cast block. Head gasket issues arise with the AL head and cast block. Do you see an issue with the gasket or is this a guess? Look at the rad to see how much sludge there is in there. Cooling issues arise with a clogged rad and lack of mantainance on the cooling system. May not be a head gasket.Just an opinion. And I think that price with that mileage is not bad at all.
semlin said:why do you think h/g? it's pretty uncommon in a 3FE. check the plugs for oil build up and give it a compression test. there are a lot of things that could cause a rough idle.
Dr Gonzo said:One pitfall is that you will aquire a lust, passion and desire for modifications as well as aftermarket parts. It is indeed a thirst that can never be completely satisified but it is pure joy.
trd55 said:Well on the way back from the test drive,(stoped at filling station to fill radiator with water)the engine kept wanting to die, and when I looked in the mirror I saw a huge cloud of white smoke. That would lead me to believe it was a head gasket. Radiator looked clean when we took the cap off.
