Possible front wheel/hub issue - need help
NC
First off, I have searched the 80 forum with multiple possible key words/phrases, I get nothing. Here is what is going on, please provide feedback, or the proper phrase to search on.
Front DS wheel has some play in it, when off the ground, I can rock it back and forth, as if the lugs are not tight. But, the lugs are tight, and they rock with the wheel. The caliper, rotor, et al do not move, only the wheel. The movement is slight, only about .5 to 1 centimeter My thought was wheel bearing, but when I looked it up, I could not find any one with issues like mine.
A little about the truck: 1996 stock, with 218500 on the clock. I have owned for 3 mos, the PO performed front axle service between 180000 and 190000. He also remained up on all other PM. He is a fellow Mudder. When driving, the truck has some slack in the steering wheel, which I assumed was part age, and part alignment. There is a little float in the drive, from the play in the wheel. My old ('77 chevy) had similar. The truck is tight, no grinding, or clicking, or rubbing. No sounds. I can turn tight circle, either direction, and get no noise.
Please point me in the right direction. We are heading out of town this weekend, Outer Banks, and I really want to take the truck - but only if it is safe to do so.
Thanks,
J
Wheel bearing.
Remove grease cap and drive flange.
inside there is the 2 bearing nuts and star washer.
See if they are loose.
Mine was loose and I retorqued the nuts to about 15 ft/lbs
You will need the large bearing nut socket, I do not remember the size off hand I think I have a 2 1/8" socket IIRC.
After you tighten it down again, spin the wheel to see how freely it spins, it is a feel thing if you know what I mean and see if the tire still rocks at the 12 and 6 position.
Does this make sense.
If there is wheel/hub play at 12 and 6 o'clock, I would normally suspect it is a loose wheel bearing. If it is just the wheel and not the hub, then there must be something wrong with how the wheel is mounted to the hub. Are they the original stock wheels and lug nuts? If not, it may be a problem relating to hub centric vs. lug centric wheels and cone vs. flat lug nuts...
Makes sense. Thank you, I searched wheel bearing, and all of them are replacement, not the loose ar 12 and 6.
The wheels are stock, and the lugs should be conical. Have not had the wheels off, yet. The truck is stock.
My guess is, the truck has been this way since I bought it. How dangerous is this? How dumb have I been driving it around the last 1,000 miles?
Wheel bearing.
Socket is 54 mm. Slee Offroad.com sells one Slee - Drivetrain - Drive Shafts or you could probably pick one up at your local auto parts store.
Caliper is bolted to the birfield housing (can't remember the correct name) and is indepedent of the hub. However, the brake disc is bolted directly to the hub and should not move indepedent of the hub, which it sounds like it might be.
I would remove the tire and make sure the bolts holding the disc to the hub are still in place and are tight. This would not explain the wobble in the hub, but would explain why the hub wobbles indepedent of the disc.
The hub moving around is usually a wheel bearing issue. Or a worn hub..or a worn spindle.
Thanks to all. My next question shows my newness - how dangerous is this? Should I skip taking it on a trip @500 miles, until I can get it fixed?
FYI, the lug nuts on a 1996 should be the flat washer type, not conical.
Personally, I wouldn't be very comfortable driving the truck without at the very least knowing what the problem was.
Okay, from what I gather from this is if you jack up the tire in question and grab the tire at 12 and 6, there is no play. Does that mean the play is when you grab the tire at 3 and 9? :confused:
There is movement at 6 and 12, no movement at 3 and 9.
I took it to a shop today, and asked them to look at it. I do not have the time or tools, and don't want to risk screwing it up worse. It should cost me 1/2 hour of labor, but that is cheaper than the alternative.
Thanks to everyone for the assist.
The bearing nuts were loose, finger loose, as the shop stated. It has been tightened, and the truck drives a little differently. The total was $43, so I can not complain.
Alls well that ends well, especially when the shop bill is less than $50. :D
