Possible cracked head
Perth
Hi guys hears a question for one that has me a little puzzled,
Firstly I'm aware the it's probably the worst I fear is true, ie cracked head or at best just the gasket, but before I go ripping of the head off I'd like to nut a few things out first,
Now bearing in mind I have just come home from a full round trip of Australia towing a caravan and not once did the temp gauge even think about spiking nor did my egt gauge barely flutter above 400c ,
But after every haul roughly averaging 500 kms a day my radiator overflow bottle would be half to three quarters full, to which after a night too cool off I would just pour excess back into radiator
now whilst on the road I figured if it ain't broke why fix it, but now home it's definately time to try n nut this out.
Any help or input would be greatly apprieciated!!!!
You'll get lots of advice, but there are a number of ways you could be loosing that coolant. You probably know if it's getting into your oil it will discolor, like chocolate milkshake, and there'll be similar residue on the underside of your oil fill cap. I'd suggest oil analysis ASAP. Cheap and hard to argue with.
Not drawing back from the overflow is an indicator of a small leak, could be a cap, hose, gasket, etc, leak. Using a pressure tester will often find the offending part.
I recently replaced a cracked head. Truck would run great besides a little miss at idle sometimes. never overheating but was losing about an inch of coolant every hundred miles. The crack was very small and took the head shop a while to find but damn it was worth getting a new one and not bolting the old back on
Start with the cheap and easy. Replace the radiator cap. If it is not sealed right, it will not suck the coolant back into the radiator after it has cooled down.
Awesome thanks for the help guys,
Yep after radiator cap replace, pressure test and some fine tooth combing problem still exists, so next step is
definatley head off, I guess after 380 odd thousand kms somethings going to give!!!
Once again thanks for the help will keep updated
Cheers Fieldsy
I guess with turbo since you have an EGT gauge? I also guess that your EGT probe is in the dump pipe after the turbo?
What did the pressure test show? If so cooling system holds pressure, it is very unlikely that the Head/head gasket has problems.
Yes mate to first two questions,
As for next I couldn't tell you exact numbers shown as was done by a friend, apparently reading a touch low but for age of engine is normal?
Righto. On a different note, when you get a chance, drill and tap the exhaust manifold and get the EGT probe before the turbo because no one really can calculate the temperature drop across the turbo because it can vary depending on the boost and so on. I ran post-turbo for a couple of months and now pre turbo, the difference is night and day, post turbo I probably would have thought I was OK in some conditions when pre-turbo tells me that EGTS are becoming high. On a 1HZ I would suggest keeping below 620-650 degrees C pre turbo or 450-500 post to be safe.
Do you know what your mate tested? Did he pressure test t cooling system or did he test the compression?
Am pretty sure was cooling but will double check now you ask!
As for egt probe was looking at changing anyway as the previous owner was the one who installed and was a bloody bodgy job at best with the welding skills as I assume they stuffed up the tapping of dump n had to hold it in somehow, which now I think about t could also possibly account for the lower egt temps.
Incidentally, this topic might be better in the diesel section @Romer or @nuclearlemon or @serenity could move this to the diesel section because most guys in the 80 section are from the US where they only got /get petrol cruisers
If you want it moved that's not a problem. Also have a look at the first section of this post here DIESEL TECH FAQ, popular mods, build threads, FSMs and more! I just added information about the cooling and lubrication systems.
And a Google search of this site will bring up a few threads regarding overheating in a 1hz that may be useful.
Yeh you will know if it's really stuffed when it starts pushing the coolant out the overflow. Sometimes with turbo engines I have had this happen I even did a tk test ( checking for exhaust gases in coolant) showed up nothing but was leaking under boost which might not even be the head gasket blown but the headgasket bolts slightly lifting under boost.
All the best Mark
Once your head is lifted the escaping exhaust gasses will torch out your gasket pretty quick via the path of least resistance. Once that path is achieved it only continues to grow. I confirmed a leak once that was hard to pinpoint by attaching a long tube to the overflow port on my rad and running it into a half full pop bottle beside me in the truck. The tube sat at the bottom and the bottle partially filled with water. I could then easily see when even the smallest amount of gas escaped as it would push out the rad and bubble the bottle beside me. Mine did it only under sustained high boost.
Great idea Greg! That ones locked in the memory bank.
For the OP
I had similar happen with my HDJ80, changed to an aftermarket rad cap, still had the problem, changed to a new oem rad cap and it was all good.
The rad cap gas a little flap valve that allows overflow water to be drawn back in. This valve failed on my original one and was a bit dicky on the aftermarket cap.
