Re-reading the requirement I just posted, it sounds like it should actually work in any position, so long as you have the temp set to HI (85F+) and the ambient temp outside is cool enoughSo will this ever activate with everything set to AUTO?
That's how it seemed to work to me as well.Re-reading the requirement I just posted, it sounds like it should actually work in any position, so long as you have the temp set to HI (85F+) and the ambient temp outside is cool enough
1 quirk to 25 fidgets?Tested it this morning at 18 degrees outside. It wasn't at all blowing toasty warm air, but it was definitely doing something. Enough to see the snow against the windshield start to melt slightly.. not that it would have worked through the 14" of snow.. but it was doing something well before there was any heat in the coolant.
Maybe this should make it into doug's "quirks and features" list for the 200.
25 fidgets equals two sweaty t-shirts1 quirk to 25 fidgets?
Concur, definitely starts pushing warmish air 3-5 min faster than the beater core does.I used this again yesterday, it does push warm air faster than the regular HVAC, but not a lot faster, maybe 2 minutes or so.
Not sure if you have 120v AC power where you are, but I get around all this by plugging in the old fashion way - with block and battery heaters. Quick heat. I also have a Webasto cabin heater (runs on fuel from the tank) to heat coolant and cabin when I can’t plug in.I've never had to do all this to get a window defrosted!
In all cars I've owned, the last few: 2008 Touareg V8, 2015 Audi RS5, 2020 Macan S and 2021 992C4S, you select defrost (front or back) and that's it. You didn't need to futz with 16 settings of fan, temp, a/c etc. I'm having the frosted window issue where the pin on the recirc shroud was suspected so I will try that, I live 20 NW of Fairbanks about 100 odd miles from the arctic circle, so yes, this is a big deal for me.
siberian
Regarding Toyota and block heaters, that recommendation was only for the 200 due to Toyota’s OEM vendor making a bad cord for the cartridge heater. Buy a KATS brand cartridge heater and you will have zero issues.Thanks for your reply and yes I do have 120 a/c (and a backup Honda eu7000 generator with a transfer switch).
Of course, Homer is a wee bit south of us but yes as we speak, I had the car winterized (meaning battery, oil and tranny pan electric blanket) but for the most part the car is in a heated garage. The issue arises when I take the car out. It's 50s in the garage and -35 or -40 outside. The window instantly freezes over - don't have that with my other two cars. Very familiar with Webasto (had a Westphalia camper when we lived in Europe and it definitely helped with air cooled engine) but my "beef" was with the number of manipulations required (disable A/C, fan on Max, outside air selection, heat to max...) vs simply pressing DEFROST and presto.
Best from 65 North
siberian
PS FWIW, Porsche, VW, Audi and Toyota do not recommend block heaters due to potential fire danger
