For Sale Portland, Oregon: 1989 FJ62 Restoration - H55F 5 Speed Conversion + 124k original Miles
Portland, Oregon
Year
1989
  1. 60 Series
Portland, Oregon 97239 United States
Mileage
124400
Color
hsl(0, 2%, 45%)
1989 Toyota Land Cruiser FJ62 – 5-Speed Manual Restoration
This 1989 Toyota Land Cruiser (FJ62) has undergone a documented mechanical restoration and modernization program with over $45,000 in receipts from 2016 to 2024. The build focused on transforming the truck into a reliable, comfortable daily driver without losing its vintage character.
Highlights include a professional conversion to a 5-speed manual transmission, a high-end custom audio system made to look period correct and extensive preventative maintenance by Land Cruiser NW here in Portland, Oregon. The truck was owned by a Nike executive here in Portland for the last 10 years and the truck has been immaculately preserved.
Below is the detailed breakdown of work performed, organized with the help of AI :)
1. Drivetrain & Transmission Conversion
The centerpiece of this build is the professional conversion from the stock automatic to an H55F 5-speed manual, transforming the driving dynamic.
  • April 2016 (Land Cruiser NW): Complete 5-Speed Manual Transmission Swap.
    • Included installation of the H55F transmission, pedal bucket, and clutch hydraulic system.
    • Transfer Case Rebuild: The transfer case was fully rebuilt with new bearings and seals during the conversion to ensure a leak-free driveline.
    • Clutch: New clutch master cylinder, slave cylinder, and complete clutch kit installed.
  • December 2015 (Land Cruiser NW): Front Axle Rebuild.
    • Rebuilt front knuckles/axles and serviced the transfer case and differentials.
    • Replaced rear brake shoes and adjusted tie rods.
2. Interior, Audio & Modernization
A "Level 3" cabin restoration featuring custom fabrication that retains the factory aesthetic while adding modern tech. The seats were refoamed with new springs, all new carpet kit, and we had the entire truck professionally extracted to bring it to like new condition. Headliner, plastics, and the all of the buttons have been cleaned and or replaced to like new. The vehicle has features a period correct remote-start system and all of the windows/door actuators were upgraded.
  • February 2016 (Musicar NW): Comprehensive Audio & Convenience Upgrade
    • Sound: Morel Tempo Ultra Integra 602 speakers (Front & Rear) powered by an Alpine Power Pack 4-channel amplifier.
    • Fabrication: One-off custom-fabricated speaker grilles for front doors and rear quarters to look stock.
    • Convenience: Installed Compustar Keyless Entry and a Nav-TV Backup Camera integrated into the tailgate handle.
    • Soundproofing: Extensive sound damping applied to doors and panels for a quieter ride.
  • February 2023 (Musicar NW): Tech Refresh ($1,298).
    • Upgraded head unit to a Pioneer 6.94" Touchscreen with Apple CarPlay/Android Auto and DVD playback.
    • Installed video lockout bypass.
    • Refreshed Door Locks + Windows
3. Recent Maintenance (2022–2024)
  • Tires: 4 New 33x10.50R15 BFGoodrich All-Terrain T/A KO2s (Nov 2023).
  • Alignment: Fresh thrust angle alignment (Dec 2024).
  • Major Service: "100k Mile Service" completed in 2022, including all fluids flushed (Diffs, Trans, Brake, Coolant), spark plugs, and throttle body cleaning.
  • AC System: Full service, reseal, and recharge (Blows cold).
  • Routine: Fresh oil change and transmission shield installed (Nov 2023).
  • Cooling System: Overhaul included radiator hoses, heater hoses (front & rear), thermostat, and water gaskets.
  • Brakes: New front pads, rear wheel cylinders, and Load Sensing Proportioning Valve (LSPV) replacement.
  • Engine Sealing: Oil pan and gasket replaced to address leaks.
  • Windows: Power window motors and switches refurbished for reliable operation.
  • Full fluid flush: Automatic transmission fluid, brake fluid, front/rear differential oil, and coolant
  • Tune-up: New spark plugs, throttle body cleaning, and timing/idle adjustment.
  • New Dobinsons IMS Suspension (2" Lift with all suspension components replaced as needed)
3. Body + Exterior Refinish
  • Lights: 4 Holley Retro-Brite LED headlights with a special harness to run 4 low and 4 high (2700K Halogen color)
  • Paint work: Re-Spray in Factory Color in 2022 with new rubber gaskets + Windshield (OEM Glass in all other locations) -
  • Chrome Trim: Replaced and restored/refreshed chrome trim and moulding accents as applicable
  • Paint Correction/Protection: Vehicle has not been polished/cut since repainting in 2022
Summary of Ownership
This FJ62 represents a significant investment in longevity and drivability with all of the major items sorted. We have receipts for all the work completed and the truck is ready for its new owner. The title in-hand (Oregon Certificate of Title) in owners name with all of the provenance to validate the restoration. With the heavy lifting of the manual swap, axle rebuilds, and cooling system overhaul already completed, it is ready for its next adventure. The stock suspension parts and OEM Radio are no longer available but everything else is included in sale. The truck was dry ice cleaned around 3 years ago and we chose to note dry ice clean + coat the undercarriage to show what a true West Coast vehicle looks like after 35+ years. Happy to arrange for that to be done at our expense if a buyer would like the chassis to look the same as the interior - same with a paint correction!
Asking $65K OBO - no test drives without proof of funds. More photos and videos on instagram @ Landcruisersociety
The truck was dry ice cleaned around 3 years ago and I chose to not to dry ice clean + coat the undercarriage for this listing to show what a true West Coast vehicle looks like after 35+ years. Happy to arrange for that to be done (I'll pay for it) if a buyer would like the chassis to look the same as the interior - same situation with a paint correction! I feel it's best to show it as-is with these older trucks - if it goes to BaT then all of that needs to be done thanks to all the keyboard experts :)
I sent you a PM. Would love to learn more.
  • February 2016 (Musicar NW):Comprehensive Audio & Convenience Upgrade
  • February 2023 (Musicar NW):Tech Refresh ($1,298).
Great truck. Still available? Interested if so
At this price point, consider placing it on BAT. Mud does not typically let loose at this price point. GLWS.
