Popping while turning slowly
Just purchased my 94 80 series and am noticing a popping when I turn sharply at slow speeds like when parking. Any ideas what it might be?
Thanks Josh
YBJFA
Birfield CV joint. Look in the 80 series faq (sticky at the top of 80 series forum), you will probably find info about it. There is a writeup (front axle service) in the maintenance section of the FAQ, to give you an idea of what the repair entails.
Welcome :flipoff2:
Read up here on birf and front axel service like firetruck. Also check local chapters/clubs, they can help you right along with the repair. :D
Service your front axle. Contact cruiserdan for parts, he's put together a little "kit" that has everything you need in it (just bought one).
any estimates on cost to get it fixed?
I had a quote done at my dealer and it was somewhere in the area of 2300, with all new parts! Luckily I bought the warranty for 1000 when we bought the 80 so the warranty paid for itself twice!
IIRC the parts (along with wheel bearings) is around $600 from Cdan.
Could have done a front end job and had some left over for :beer: for the cost of that warranty. :lol:
Yeah but for an extended 25000 mile warranty on a vehicle that at the time I knew nothing about when I got into it was a nice piece of mind when we got the warranty! I discovered Mud after I had the 80 for about 6 months so I didn't know about the plethora of info I would find in here. I will tackle it about 150,000 miles from now! :cheers:
"IF" they replaced the BIRFs with new ones you did well. If they just repacked with fresh greese and closed it up, we will see. It is interesting that they covered a wear item under warrenty. Good for them!
OP,
Read up on front axle maint. The clicking you are hearing may or may not go away with a regular birf job. If the BIRF's are worn enough only swapping sides or replacement will make it go away. Some feel swapping side is only a bandaid. Do your research and make your decision based on your needs.
:cheers::flipoff2:
I just picked my 94 up today from doing a front axle rebuild including new OEM birfs and drive plates from CDAN (thanks!). Birfs were about $540 USD a piece and each drive plate was a little over $40 USD. This job is a bit beyond my technical ability and patience, so I had it done at a reputable front end shop that does work on Cruisers. $395 CDN for labour, and they also put in new bearings on the DS. I have only driven it about 15 miles since, but it turns smooth and quiet now.
:cheers::flipoff2:
They replaced with new, and to tell you the truth it might have been a little more. I am still really happy we got that warranty!
