you'd have to have custom axle shafts made and some custom side bearings i think....Sputnik40 are you running 42's?
thought 39"
question to people who break rear axle shafts all the time.....are your diffs welded up? also what gear ratio are yall running and what kind of backlash # did you set the rear-end up with?
I'm ARB locked, both breakages was when Tencha was locked, turboed, intercooled and chained .. and heavy right foot ..
What does gears or welded diff have anything to do with axle shaft failure?
more stress to the axles .. ?
To the GM12 issue .. GM R&P ? plus GM spool or can be done with a GM ARB as well .. ?
