I have the code PO420. I know that usually means either a leaking in the exhaust between the O2 sensors, or a faulty o2 sensor. I have checked every connection around and between the O2 sensors on the exhaust and cannot find any leaks; with the exception of just a little bit of a leak where the y-pipe connects to the exhaust manifold. Don't know why one of the two connections leaks but it does just a little. THat seems too high up to throw this code.
So before i jump in and buy two new 02 sensors, the FSM shows a testing method where you ohm out the plugs on each sensor.
my question is this since the FSM is just a little vague. THe FSM says to warm the vehicle up by driving it for a few minutes and then test the sensors by unplugging each one and using an ohm meter to test each sensor. So... do i do that while the truck is running (that's what i think is correct)? Or, do i let them warm up to operating temps, then turn the truck off and test them? Seems they will not be functioning if the truck is off.... right?
simple but just wanted to check before i spent $160.
