Po401- Aahhh!!!!
I have the same problem and have another similar thread going. I am just wondering where you guys got your vac line at.
And I hope this doesn't come off as a foolish question but when you pull the TB and top half of the intake manifold do you most generally have to replace the gaskets? I was think about getting the manifold clean via a mild media blasting . I figure that would get just about all of the gunk out. Granted it would also require a good cleaning to insure all of the particulate matter from the media blasting has been removed.
Any thoughts on this?
I am going to replace all of the vacuum line over the weekend and test the EGR modulator and VSV and clean the EGR temp sensor (any recommendations on cleaning this sensor).
Thanks
Pete
Thanks
Pete
Gaskets are FSM recommended to replace although the TB gasket could be re-used in a pinch. Cleaning the EGR temp sensor takes a few second with a wire brush. It takes longer on a pre-95 due to the location of the sensor.
Guys just wondering about my method of cleaning I discuss above.
Anyone with any thoughts on this?
Well a quick update for the thread and for those who are interested.
I replaced a good portion of the vacuum line today. All that was easily accessible from the top. Checked the EGR modulator and cleaned the EGR temp sensor. Dang if it didn't have about 1mm of carbon deposit on it. I have a strong feeling that was the cause of the doomed P0401 code. Anyway I cleaned it real good with a wire brush and re-installed. The code is now gone. For now that is.
I still plan on replacing all of the vacuum line under the top half of the intake manifold when I remove it to give it a much needed cleaning.
I will keep all those interested informed as to my progress.
Have a great weekend everybody.
Not to burst your bubble, but I did that last fall and still had the code coming back. Grab a TB gasket, 14mm socket and extension, some TB cleaner and a small screwdriver/dental pick and clean out the EGR tube in the intake manifold. If your temp sensor had that much gunk on it, imagine what the inside of that whole passage looks like! Takes an hour, maybe two, but judging from the amount of carbon I got out of there, definitely worth it.
Adam
No need to burst my bubble, the dang thing came back on this afternoon. Well the next step is to give CDAN a call and order TB gasket, Intake manifold gasket, and a few other odds and ends. Then give the intake a good old fashioned cleaning. Next weekend hopefully.
The Saga continues.....
so i disconnected my battery to clear my p0401 code and it cleared now my D light shut back off! :rolleyes:
But at least i dont have a check engine light after cleaning the hoses!
