Okay, i know this has been beaten to death over the years but....
I've got a 97 with 107K miles that has a CEL with a PO171. I should mention that I live at 7000' elev. So far I've tried or have replaced recently; new plugs, wires, dist cap + rotor, new factory air filter, checking all connections, replacing fuel filter, replacing O2 sensors(with factory ones), replacing EFi relay, cleaning MAF sensor and pulling out what little hair I have left. Some of the symptoms are: hard starting when engine is warm (cranks over for a long time before firing), down on power to the point that when driving up one of the hills on the way home it feels as if it not getting any fuel and will die on occaision (hasn't yet) also when reving the engine a little at idle there is a small but noticable hesitation/miss between 1500-2200rpm. this vehicle does have 315/75 tires but I installed 488 gears in it when the tires were installed. I'm a diehard old gear head but my experience with all these sensors and computers is somewhat limited. If I can't get it running like it should before long, I have a feeling the wife is going to want it gone for a more reliable DD. HELP!!
