- Joined
- Sep 5, 2012
- Threads
- 1
- Messages
- 6
OK so i finnally got my truck ready to drive to take emissions and on the way there I realized something was wrong. While driving i get a very violent vibration. It comes in 3rd 4th and 5th Gears about 90 percent of the time. 1st and 2nd gear dont do it. The cab starts shaking pretty good and there is a grinding sound coming from the drivetrain somewhere. The problem is not speed related because i can go 45mph in 2nd gear and no vibes but as soon as its in 3rd it starts. The vibration happens while in the lower rpms and sort of smooths out in the higher rpms. If i push the clutch in while driving and vibrating it goes away so i assume that eliminates the chance of it being a drive shaft vibration right? because the drive shaft is still spinning at the same speed and the vibration is gone. i put the truck on jack stands and ran it and it sounds like its coming from the tranny. I checked the clutch and pilot bearing and thro-out bearing and all seem to be fine with no slop. There is No play in the rear pinion flange or the t-case flange Please help me dianose this problem any input is apreciated thanks.
