plugs, wires, rotor, dizzy cap - easy
Norwich, VT
I had a wet weather hesitation and stumble on cold starts and I was thinking I was about due for some attention to the IG portion of the manual. So $111 or so later (:cheers: Cdan) I had the parts. If you're thinking about doing this but are worried about how many bananas...don't worry its easy. The fsm reccomends removing the throttle cable - I didn't bother. I did however excercise extreme caution when removing the air intake tube...no mention of caution in the fsm but having lurked 80's tech enough I took care and ran into no troubles cracks etc...Its raining like h-e-double hockey sticks right now but I've not yet tested out out the cold start wet hesitation symptom yet...it was a sporadic thing at best anyway...my plugs groaned alittle on removal so the new ones went in with some antisieze on the threads...My 5/8 plug socket on an extension worked fine (I didn't find a 16mm plug socket in my pile 'o tools...) and after I pulled the extension out of #1 without the plug socket:rolleyes: I used electrical tape to attach the socket to the extension...worked puuuuuurfect...Anyhow...if yer scrathin' your chin about doing this...don't hestiate its easy...flippin' wires an cap are even labeled #1-#6...even I didn't screw it up...
:beer:
Rob M
I just completed my tune up today and agree it is easy. This is especially true if you get the CDan parts. The spark plug wires are all set up in the wire cable trays and fit perfect. I did loosen the throttle cable to gain access to plug #5 but not a big deal. I used anti seize on the plugs and used a combination of the orginal spark plug wrench included with the jack kit and a socket set.
The PCV valve grommet did break off and fall into the valve cover. As folks on the board state you can easily pull it out and was able to do it with a small clamp tool. CDan also sold me new PCV hoses and replaced those with the original clamps. I really like how easy it is to replace the rotor and cap. The wires plug in with out a problem.
02 Sensors were a 6 hour nightmare yesterday but that is seperate story.
I highly recommend that everyone do this themselves..you'll save money and enjoy the experience. My rig runs a lot smoother now and acceleration has improved. I hope to see a gain in gas mileage.
Dave
I have done 2 tune ups in the last few months and agree it is pretty easy. 02 sensors nuts can be a nightmare. Luckily I have 37 inch arms and therefore #6 was not bad on either of my rigs :flipoff2: .
Smit
And--the local dealer charges $1600 to do a tuneup with 02 sensors. And that does not include additional fees for stubborn 02 sensor studs that need to be replaced!
My cost--about $400. Thanks CDan !!!!
Please tell me the diesel fuel filter is easier to change than the gas fuel filter.
Sure is , unbolts from its mount and put it in the vice and away you go. 5 minuete job max.:rolleyes:
So curious guys, any ideas where to find a 16mm plug socket?
My local tool shops that I was from mars when I was asking for one.
In the factory tool bag. That's what I used when none of my spark plug sockets fit. It works perfectly even for the difficult #6.
Sears does sell ones that fit--I went to sears with an old plug and got one that;s perfect.
I think you can get one from Motorcycle places.... like JR Graham or such. Dan may also be able to get you one. Have you tried Craftsman also?
I did mine when I first got my LPG cruiser (it's more critical on LPG cars), easy, but the plug by the firewall was a PITA (moreso on mine 'cause of the extra LPG pipework). The plus looked liek they might actually have been original (about 100k miles) - virtually no centre electrode left, gap about 1.5mm !
One question.. anyone looked at aftermarked ignition leads ? The OEM ones look micro-weedy ? I need to finish up a conversation with a supplier I found on the web that make leads up, they need some photos of the boots -http://www.auroraignitionwires.com/
Cheers - JB
They probably looked at you funny because there's no need to get a metric socket. The standard equivalent 5/8" works perfect. When you get one make sure it has the rubber retainer piece inside. If you use one with the correct length extention you'll wonder why anyone ever complains about #6 being tough to access. Much less cumbersome than the tool kit socket.
Craftsman Spark Plug Socket - Model 43327 at Sears.com
Cheers - JB
they look weeny but their designed to work with everything else.
i have an oem set on my 93, that i'm pretty sure are teh originals. they are marked 93, the truck has 200K on it and still drives fine....they are of course on teh real short list of things to do...
