please review my front end setup
searching is good but it can often throw you through a loop with all the opinions out there. setup is an SOA with shackle reversal. For the reversal- cut the rearward hanger from the frame and weld to the current location of the front hanger. drill hole in frame for the rearward shackle and use a shackle that gives length of stock position. (meaning distance from buttom of frame to eyelet center of spring). This would give me a little more caster since i have eliminated the 2.75" stock shackle in the front, and lower my ride height a little over and inch, correct? i will be reversing the front springs, giving me an added wheelbase of 3.5"-4". Does this make sense? i have the frame bare to work on with no motor or body on it. Since there is no weight on the frame finding my angles is difficult. Can anybody give me a good idea on how much to turn the front knuckles? The factors are the added front wheelbase and a 350 700r4 combo with a toyota turbo case. If you have better ideas or what i say doesn't check out, please let me know.
Wow, quite a few questions. I suggest you wait until you get some weight in it as this may throw off the height front to rear. No idea on how much you will need to rotate. End up with +3-6*. Only you can detemine this. Go buy a cheap angle finder from Home Debit. Again, I would wait until you get the correct weight on it.
Based on the type of questions you ask it sounds as if you are thinking in the right direction. No one is going to be able to answer them specifiacally, though as you are doing your own backyard engineering. Good luck and post pictures as you go. I have found I get the best help when I ask specific questions and state the givens so people don't suggest the obvious.
okay, thanks! however, It seems that if i have the engine removed i can drill holes in the frame for the shackle and place a long stick through both ends of the frame to get a straight line. I desire the front shackles to be at a 45 degree angle. How far away should the top of the spring eye be from the frame to keep it from contacting during suspension compression?
You read Jack's writeup yet?
Jack Rice SR FJ40
He mentions being aware he may need a different shackle design if he has interference problems. He does outstanding fab work and he wheels his trucks. He's also a great guy (imagine that). You could petition his help (forum, email, phone, etc.)
ps - nicely done on the "specific questions" :D
i did veiw jack rices setup. Here is my current question/dilema. Jack has his shackle angle almost vertical. I am under the understanding that i should shoot for a 45 degree angle. If i drill the hole foreward about 2.5" of the current spot and use about a 5" shackle it looks like i can achieve this. Will running a 45 degree angle on the shackle help the ride on the street as well as flex?
For a SOA set up with the stock flat springs, the only thing you need to be concerned about is that the shackle lenght and shackle angle accomodate the full range of movement of the suspension.
For a stock flat spring, having the shackle angle at 45 degrees actually increases the overall spring rate (and stiffens the ride) compared to straight up 90 degrees but the effect is so small that you won't notice it.
