Please help a 1996 LC owner
Took Mom for a couple of days off from the kids before school starts. Burnt the engine to toast. Small hose below intake vented all coolant and cooked the engine. Need an engine , 4.5 inline 6. Please, any ideas. My other option is to sell the really good body. Right now I'm in a bind and could use advise from some guys that are in the know. Please feel free to email me. Im in the Southeast US, truck is in Florida. Hope the Lord works through one of you guys and helps me with some answers.
Thanks a lot guys, Fred
Tough spot. Best advice? Unless you're skilled, with tools and space, find a shop that you trust and start doing some internet legwork and find a good runner, close to you and get 'em hooked up.
What with Obama's engine destruction plan in full swing, there's a shortage of good running 1FZ-FE's I've heard!
GL, Dan.
Pretty good chance you just blew the head gasket. That's much cheaper that a new engine.:hhmm: Good luck:cheers:
These engines are hard to destroy, you may find that it needs much less than a new engine. Trick is to find someone knowledgeable about the 1FZ-FE, best bet may be a local cruiser head consult.
sounds like you blew the phh pesky heater hose located above the starter, beneath the intake manifold. did you take it to a reputable mechanic? the engine may be salvagable, if you didnt run it for a length of time after the hose blew. best case scenario: replace the hose with one from GreenStripe flush & fill the coolant. worse case scenario: motor overhaul or replacement. good luck.
If you search threads or the faq for "PHH" you will find info/pics of the "pesky heater hose", the fix is cheap even if a bit of a pain to do , and then you can see how your engine is working. Worth a shot!
How long did you let it run after the guage read Hot? Did you keep pushing. If not, you may not be looking at a lot of money. If you refill the system can you crank and let it run or is it locked down?
I wish it were a head gasket. As I'm sure you guys know the check engine light has been on for 2 years. I didnt know it was running hot as I was in 6 lane Orlando traffic doing 70. The truck never put out steam that would show it was hot. Never a puff of staem like overheating normally would do. I didnt have a clue untill it started fluttering and turned off. The head is warped 20-25/1000 . 2 pistons dont look good and have aluminum on the tops. I really cooked it. There wasnt a drop of coolant in the system.
Still trying to figure out options.
Thanks for the help guys, I appreciate the replies
Fred
ouch. it sounds like you are shopping for a used motor or another 80. Or using this as a clunker trade-in, since it seems like $4500. may be top-dollar for your rig.
The check engine light may not have been related to the coolant failure. You can still pull the code if you're curious. I'm guessing something else led up to this, because it's hard to blow a hose at 70mph and not see and smell lots of steaming antifreeze.
Stuff is out there. Did you check the classifieds here?
Hey guys, Found a engine with 66k that was delivered to my tech for $10. Thanks for your help.
Fred
WTF:whoops: Where did you get that? Are you sure that is $10.00 american usa dollars? Is that just a delivery fee or the whole engine? Either way you luck out. Good luck:wrench::cheers:
See, I told you don't give up:lol:.
