Only difference I can think of would be volume of vacuum available to the system? Does the small one have a port for the vacuum sensor idiot light sending unit thingy?
Maybe the earlier vacuum pumps didn't draw as hard and required a larger volume to compensate for the lower vacuum?
Is it just a simple pipe connecting Pump-Tank-Servo with no valves?
Ahh right, thanks! My electric pump and tank just arrived so great timingYes, the pump should have a built in valve that senses how much vacuum is in the tank. When there is enough it stops making vacuum.
Diesels don't make a lot of vacuum in the manifold , this is why they have the vacuum pump . Its also why your brakes are very hard. So, block it off.
Which electric pump did you go with?Ahh right, thanks! My electric pump and tank just arrived so great timing![]()
I bought a used pump on ebay which was from a fairly recent landrover iirc. I also bought a small reservoir from an Isuzu trooper, and a pressure switch from alibaba...Which electric pump did you go with?
Yea it looks exactly like that.One like this? : 2005-2009 Power Brake Booster Vacuum Pump - LR3, Range Rover, Range Rover Sport - (4.0L, 4.2L, 4.4L) - SQJ500082 - https://www.roverlandparts.com/05-09-power-brak-boost-vacuum-pump-sqj500082.aspx
