Piston ring end gap F engine
You might what to start at lower end as the gap will increase as the cylinders wear and performance will suffer.
Hmm, a typical rule (if there is such a thing) is .004 -.0045" per inch of bore, so a 3.54" bore would want a .0141 -.0159 gap.
That is at the upper end of the gap range I see for the top ring (.008-.016) and greater than the range for the #2 ring (.006-.014).
I am certainly not an expert. I'm curious what actual dimensions have worked for people currently doing this with current new parts.
