I'm not sure what caused this problem, so here is all of what I think is pertinent background info:
My 40 has new gears and bearings with an ARB in the rear third, all set up and installed 2 weeks ago. All installed by a transmission mechanic who has done many, many gear setups.
I was not able to properly break in the gears, they recieved about 5 miles of slow speed driving and then the truck was flat towed 150 miles to tellico, where it was wheeled for 2 full days, then flat towed 150 back. It has since gotten maybe 5-10 miles of surface street driving.
While driving it today, a drivetrain rumble was brought back to my attention, I had noticed it in a more subtle form immediatly after installing the new gears, but did not take serious note as I was too focused on making the impending trip.
Symptoms-slight rumble at no acceleration, hard acceleration in 2nd brings a fairly serious rumble. If I feather the throttle while coasting I can get a metal grinding noise-I bet this is the pinion preload shims. Deceleration brings a rumble similar to acceleration.
I read the Rumble...Rumble.. thread and decided to go out and check my pinion nut torque. Did not feel loose, yanked the nut, loctited it, and threw it back on. Torqued it to 140#'s a la Pinhead's post copied before. Now I cannot turn the flange by hand.
Here is what I think is the problem-The gears and bearings were already in the third member as I had a different mechanic try to set them up a few years ago, he couldn't, so i bought a used third. I think the mechanic that set up my ARB with these gears and bearings thought that the third had been set up correctly when in fact it wasn't, and didn't bother to check wear pattern etc..
Also, the pinion nut is not a stake nut, so it may have loosened and worn the shims.
I was planning on pulling the cover and checking wear pattern, but now it looks like my best bet is to pull the third and take it back to the shop. I'm a little afraid to tighten the pinion by feel like PH suggests, I would with old gears, but this is all new stuff and it would be a shame to mess it up...
Any input or suggestions etc would be appreciated. Thanks.
The preload is set by shims and bad things can happen to the shims when the nut backs off and the shims spin. The possibility of wear on the shims makes just tightening the nut back to 140 ft lbs iffy. You don't want to over tighten it or the bearing will not last long. Check the preload before and after tightening the nut. If it takes noticably more torque to turn the flange after tightening it, then you need to reset the preload using new shims. Alternatively, you can just start backing of fthe nut until the flange turns easily and then tighten it back a few more degrees. This is just guessing about the preload, but being a little loose is much better than being too tight. If it is too tight you will be luck to get 100 miles out of it.
