Pinion Flange.
Vancouver, BC, Canada.
Website
www.paool.com
Thats not off my Fj, but the picture serves its purpose. Which end the "pinion flange" located on? I've always thought It was the bigger end (bottom). The reason I'm asking is becuase I recently had my truck inspected and to pass, this is an item I need to clear up. The inspector said the pinion flange was loose, and I'd get away with just sinching it back up. However, The bigger end doesn't appear to be loose at all. Its the smaller end, where the drive shaft attaches to that seems to be leaking a little bit of grease.
Could somoene clear things up for me a bit please?
The pinion flange is the rectangle at the top of the picture, the part where the driveshaft bolts up. The inspector might mean one of two things: (1) the driveshaft bolts are loose on the pinion flange or (2) the big nut holding the pinion flange onto the pinion is loose and the bearing preload is therefore not right. If it is number (2), you might better do some searching for how to get it tightened properly.
try torqueing the big nut to around 90lbs iirc.
See what slop is there after you tighten it down.
Good Luck!
Rezarf <><
Do a search on some threads where Pinhead has commented. He seems to be the most saavy when it comes to differentials. From my recollection, when the pinion runs loose for a while the outer bearing goes bad. In addition, there might be some odd wear on the ring and pinion. What many folk do is pull then nut, check the outer bearing, replace the seal, put the nut back on a torque it carefully, and run it.
Dang dude, that PO really took care of that rig for you huh... :frown:
I tightened mine down once and shortly after that the bearings went out. They usually get loose for a reason and once they've been driven on loose for a while the damage is already done. You could tighten it down to pass insp but I wouldn't expect it to last too long, maybe a few months. my .02.
only one thread exists that currently contains any input by pinhead according to the search. Are you sure you spelt the name correctly?
I just unbolted both ends of the Drive shaft as I have to fix a worn U-joint, and Gear oil started puking out the pinion flange. No kidding its loose.. I could turn it by hand.. though, maybe it was just play in the gears or something I'm not to sure, I only got 1/8th of a turn on it before I couldn't turn it anymore. And it only puked out about 3 or 4 tablespoons worth... I guess enough to fill the cavity between the flange and the mating surface on the Drive shaft. I'm pretty sure thats not normal though is it?
Actually the PO was pretty good with maintanence. But before he sold it He was crazy busy with his trucking career and had no time to go wheelin or fix up the minor things wrong with his rig. Its hardly leaking at all when you look at it from underneath so he probably just attributed any play to the worn U-joint. I'll keep that in mind. Although Its gonna cost the same to get someone else to fix it if I do it now, or later anyway, wont it?
JamesM said:
only one thread exists that currently contains any input by pinhead according to the search. Are you sure you spelled the name correctly?
I guess it must be Mr. Pin_Head.
The pinion nut needs to be torqued to 150 ft lbs, but you can't just crank it down and go. First, measure how much force it takes to turn the flange using a fish scale or something like that. Then start tightening the nut in 20 lb increments and measure the turning force. If the turning force increases by more than a few pounds by the time you get it torqued, then the preload shims are shot and need to be reset. It is far easier to just buy another good used 3rd member.
Buying a new third member will be my last resort. I'm scared to even look at what that would cost me. Never mind tracking down a good one. What would It cost (roughly of course) to have a shop rebuild it?
For now, lets assume that the Preload shims are still good. What is the best course of action for re-tightening the Pinion nut? You'll have to excuse my relative ignorance but I'm not really following you on the whole fish scale thing. Could you clarify that a bit?
this is turning out to be a can of worms... I still have to replace the suspension system, u-joint (which napa gave me the wrong part for! ugh...), Washer system, and a bell-crank/center arm bushing. Its gonna be a fun week or two for sure! $$$$
thanks for the help thus far though.
Haveing a shop rebuild your third will be pricey. If you pull it and take it in, and they reuse your gears and replace the shims and bearings you'd be looking at upwards of $300 probably. If you go to the classified section of this web site and find a guy parting out an axle that has the right ratio (not hard if yours are stock) you'd probably be looking at 50-100 dollars, plus shipping on 40ish lbs if it's not in your area. I know what I'd do. There is a guy in Sacramento (Orangefj45 or something) that sent me a pair of arms from an early axle he is parting out. You might start there.
Used thirds often go for around $100. Installing one is not that hard,
especially on the rear. I might try a pinion seal and the turn of the
nut method Mr. Pin_Head describes first. Ths siutation HawkDriver
describes sounds exactly like what will happen if the shims are shot
and tightening the nut gives you too much preload.
I got mine(used diff) for $200 to the door. It works great. 90 day warranty.
www.Cruiserparts.net
You need a factory Chassis manual of the haynes manual so that you know what parts are what and what they do.
Start by replacing the seal and checking the outer pinion bearing. If the bearing is bad, just get another diff.
You point is you need to figure out in a general sense whether the bearings are too tight after you torque the nut back down. Probably the easy way to do this is to remove the rear wheels, disconnect the drive shaft and turn the pinion flange when the nut is loose and there is no preload. You can either do this by hand, or you can hang a fish scale off one of the holes in the flange and pull it until it turns to record the force. Then start tightening the nut. If the force to turn it increases by more than a few pounds (eg it is noticably tight), then the preload setting shims have gotten ground down and need to be replaced. If you try to run it with the reload too tight it will only last 50 miles fefore the bearings burn up. If you can tighten the nut to 150 ft pounds and it still turns easily then just stake the nut (or put a cotter pin in it for early diffs) and you are good to go.
It will only cost about $300-400 to have a shop replace the bearings and set the preload. Good used ones are $50-100 and they are easy to find.
