hello all,
Before I start taking measurements and consider adding shims I wanted to post pics of my front and rear drive shaft and pinion angles. I figure many of you experts can look at the photos and give your suggestions. I understand I need to take measurements to be the correct shim degree.
Front:
Installed AAL and 1" extended shackles. The pinion looks to be turned up. Adding a shim with the fat part towards the front would rotate the axle and possible correct the caster?
Rear:
Installed AAL and 1.5" extended shackle. Once agin same scenario as the front it appears. Get measurementsfor shim degree and fat part installed facing rear axle to rotate the counter-clockwise?
Front:
Rear:
