Pinion angle
Carson City, Nevada
Im getting ready to weld the spring pads on my 14 bolt. Just curious as to what pinion angles some of you have set in an axle swap or spring over mod?
It all depends on the output driveline angle is for single u joints on each end of the d/s. Double cardon joints a couple degrees below the t/case output.
Thanks for the input. Im probably going to have to run a double cardan joint set up. Im going to have a very short driveline and steep angle.
